Parking brake issue '05 6spd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KodiakToyTRD, Dec 9, 2011.
  1. Dec 9, 2011 at 10:09 PM
    KodiakToyTRD
    KodiakToyTRD [OP] Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Problem: Parking brake will not hold truck, even on a small little incline. When parking brake is engaged, truck will move forward when put in gear and pressure let off the clutch.
    I just took the truck over about 600-700 miles in the past 5 days and prior to this last trip (today) it worked just fine.
    Its been exceptionally cold here, below 0 nights...could this be an issue?
    What are some things I should check first before taking the damn drums apart?
    Mechanical experience is not an issue here, just looking for a good starting point to begin eliminating problem points.
  2. Dec 9, 2011 at 10:15 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    did you notice if the handle got easier to pull back since it started occuring?
  3. Dec 9, 2011 at 10:17 PM
    KodiakToyTRD
    CO
    Not really. I just noticed it this evening around 4 hours ago. I'll check that tomorrow when I go to work.
    I'm thinking the rear brakes are in need of a little TLC and R&R....:(
  4. Dec 9, 2011 at 10:22 PM
    BMOC
    Paden
    Phoenix, AZ
    oh dang, my theory might not work if you haven't recently had your drums changed.
    just did a drum job on my friends sentra and after i was done, the parking brake was pretty much nothing, lol. after a couple days the auto tensioner tension'd itself back up. :eek:
  5. Dec 9, 2011 at 10:24 PM
    BMOC
    Paden
    Phoenix, AZ
    ahhh, so that's how you do it.. haha
    i'll make sure to remember that next time i do a drum job
  6. Dec 9, 2011 at 10:28 PM
    KodiakToyTRD
    CO
    I'll try the reverse roll too....but that didn't seem to work earlier when I was trying to get the damn brake to work...I ended up just putting it in gear and using the brake...
  7. Dec 9, 2011 at 10:31 PM
    KodiakToyTRD
    CO
    :rolleyes:
    Lol definitely gotta check for shit back there!
  8. Dec 10, 2011 at 8:10 PM
    KodiakToyTRD
    CO
    So here's some splatter and what appears to grease build up only around the air fill tip. This is the left rear wheel.
    I did the roll in reverse and hit the brakes, no joy.
    Stopping distance and ability has not decreased.
  9. Dec 11, 2011 at 5:18 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    There is a TSB that has something to do with tightening the nuts on the brake cable. Is it possible the locking nuts are loose on yours and the cable went slack?
  10. Dec 11, 2011 at 5:47 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    You can remove the cupholder and adjust the slack on the e brake cable as well - as your brake shoes wear this adjustment helps them engage enough to hold the truck.
    The grease and grime on your wheel makes me think you've got other problems though - a leaky wheel cylinder perhaps. I'd pull the drum and inspect before you do adjustments.
  11. Dec 11, 2011 at 5:56 AM
    DrewH
    DrewH Well-Known Member
    Could be a bad axle seal... if the seal is gone it can leak into the drum and cause the brakes to not work. If you open up the drum , it will be easy to tell.
  12. Dec 11, 2011 at 6:44 AM
    Tookie
    Tookie Well-Known Member
    Port Vincent, LA
    2009 DC TRD Sport
    Did you try it again, after everything is warmed up? If water
    got inside the drum, they could be frozen
  13. Dec 11, 2011 at 9:20 AM
    JKD
    JKD Well-Known Member
    Rear brakes probably need to be cleaned and the adjuster mechanism inspected/cleaned and adjusted manually to get it back into spec. I would be surprised if your rear brakes need to be replaced yet.
  14. Dec 11, 2011 at 12:57 PM
    KodiakToyTRD
    CO
    Its 37 right now and the brake seems to be holding...not sure how well. I still stuck it in gear as a backup.
  15. Dec 15, 2011 at 10:22 AM
    KodiakToyTRD
    CO
    Well my dad just stated that it smells like its a shaft oil seal is leaking. FML.
    Looking at the manual, this appears to be quite the process to remove and replace, can someone give any insight on this process? Perhaps an easier way to replace this seal.
  16. Dec 15, 2011 at 2:31 PM
    DrewH
    :cool:
  17. Dec 15, 2011 at 2:52 PM
    Tookie
    Port Vincent, LA
    2009 DC TRD Sport
  18. Dec 15, 2011 at 5:33 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I've done it on an 86. I don't think the basic design has changed. It does take a press, but not complicated, just takes a bit of time. Probably could get it done at a shop for a couple hours labor plus parts. Yeah, I know that's not exactly cheap, but could be much worse.
  19. Dec 15, 2011 at 6:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    I have had two seals fail on the same truck. First was clogged breather, second was worn bearing. Worn bearing will be heard as a loud roar that increases with road speed.
  20. Dec 15, 2011 at 6:15 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Auto adjusters on some Toyotas (not sure on the Tacoma) actually operate every time the parking brake handle is pulled. Might want to check and see which system we have before wasting a bunch of time backing up and pulling forward in the driveway.
