Parking brake issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Mar 25, 2016.
  1. Mar 25, 2016 at 8:19 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    2006 access cab, 4x4, 5spd manual, 4cyl..
    Replaced my rear shoes and drums today....one at a time....followed the procedure in the manual... One at a time....fully tight than back up 15 clicks....before my parking brake would work on a steep hill...not anymore! Tried adjusting the cable under the center console and again at the drums..no joy....it stops a roll on a very gentle slope...but that's it....any guesses?
  2. Mar 25, 2016 at 8:52 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Does the handbrake feel normal? New shoes take a while to wear in for maximum hold, but this sounds like more than that.
    R0dzilla75 likes this.
  3. Mar 25, 2016 at 9:13 PM
    freshman
    freshman Well-Known Member
    pressing the parking brake several times or numerous times will adjust/seat the new shoes to its proper place
    wilcam47 and R0dzilla75 like this.
  4. Mar 25, 2016 at 9:28 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Were the drums turned or replaced ? If not the surface is irregular enough that the new shoes are only hitting and pushing the high spots. Not fully seating, add to this the new shoes radius is different than the drum, so the contact area between the 2 parts is reduced. This is normal, but can be addressed by turning or replacing the drums.
    The rough surface of the new or turned drums will abrade the shoes and allow them to seat sooner the radius contact will wear in over time. Radius dressing shoes used to be a service but has been discontinued because of the hazards of the dust created. ( don't blow the dust out of drums with and air blower, it is carcinogenic and can cause you problems )
    R0dzilla75 and jasonct like this.
  5. Mar 26, 2016 at 6:23 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  6. Mar 26, 2016 at 10:20 AM
    kidthatsirish
    Yes it was new shoes and drums.... That's why I'm so confused, it should be rather tight. The parking brake handle felt normal.... Now that I have it adjusted super tight it's still not holding the vehicle other than on a very gentle slope. Rather confused by this.
  7. Mar 26, 2016 at 10:41 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    have you tried to "auto adjust " the shoes ?
    EVERY rear drum brake vehicle these days has an " auto adjust" feature, not all work the same way, but they work most times.
    it may take a few times to do this, so you have to be patient. backing up and pumping the brakes hard, multiple times, working the parking brake handle in the same manner repeat the process ( you'll have to work the handle so it doesn't stay set )
    there should be a reasonable drag on the drums, hard to turn by hand, they will self clearance as they seat. once they seat ( it will take a few trips ) the wheels will turn freely.
    another thing to consider, is the park brake cables are stretched far enough that the cable adjusters cannot take up for the extra any more, you may have a broken cable inside the housing and not see it, the equalizer is only pulling one cable ( I see this a lot on the forklifts I work on, the brakes are very similar )
    pull the center console there the equalizer is, see if it is pulling even. if the 2 cables are not even, they aren't pulling equally and you may have a cable issue
  8. Mar 26, 2016 at 10:48 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Drive it, carefully at first, to help seat the new shoes to the drums. It should be up to normal parking brake holding torque in a few thousand miles, but a noticeable improvement after a few hundred.
  9. Mar 26, 2016 at 6:59 PM
    kidthatsirish
    Well as far as I know the 06 Tacomas are tightened each time the parking brake is used....the other night I did it about a good 20 times and it still did not tighten enough....brakes are barely dragging even if I tighten the actuators all the way at the individual cylinders! I'm thinking that I'd by my next oil change this problem has not fixed itself I will probably have to replace the parking brake cables.....it's a manual with a 130k most of which is used in town so I use my parking brake numerous times every day.
  10. Mar 26, 2016 at 7:01 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    where you located ?
  11. Mar 26, 2016 at 7:19 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    back up
    hit park brake
    repeat
    should get them set
    wilcam47 likes this.
  12. Mar 26, 2016 at 7:37 PM
    kidthatsirish
    South Oklahoma city
  13. Mar 26, 2016 at 8:28 PM
    kidthatsirish
    Tried that...no joy :/
  14. Mar 26, 2016 at 8:39 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    I'm on east coast, little to far away to be of any more assistance but an armchair wrench.
  15. Mar 27, 2016 at 6:41 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you cannot lock the wheel up when adjusting the star wheel at the cylinder than you have something put back together incorrectly.
  16. Mar 27, 2016 at 9:13 AM
    kidthatsirish
    Hard to think that when it drives just fine? I don't know how else it could be incorrectly assembled.
  17. Mar 27, 2016 at 9:57 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maybe you think its driving fine because the front brakes do most of the work. Maybe the new drums are incorrect, did you match them up with the old ones?
  18. Mar 27, 2016 at 10:05 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Do the parking brake cables move freely, and return fully when the brake is released? You'll have to pull the drums to verify this. I'm now thinking that one or both cables is seized within the sheating and you are trying to adjust the brakes with the parking brake partly applied, even though the handle is released. Cable stretch is NOT your issue if the pull on your handle is normal, but something is clearly wrong if you can't lock up the brake with the star wheel adjuster.
  19. Mar 27, 2016 at 8:50 PM
    kidthatsirish
    So I just took everything apart and started back from square one...followed the book step by step again....seems to be working now...the hand brake is still not as sttong as what it was....but much stronger and I think with a hundred miles or so it will have more contact and be just as strong as it used to be. Thanks for the advice guys...sorry I don't have a gotcha culprit to tell you about....I'm thinking that I must not have counted the number of clicks properly the first time when I backed the star wheels? Oh well....good for now.
  20. Mar 27, 2016 at 9:22 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Good for you for going back in and checking things out, no reason to apologize, there may not be one smoking gun causing the issue.
