Parking brake light trips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eccracer104, Oct 11, 2011.
  1. Oct 11, 2011 at 11:13 AM
    eccracer104
    eccracer104 [OP] O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    My parking brake light on my dash trips when my parking brake isn't engaged. I'll be driving along and it will light up for a few seconds then turn back off. Happens frequently when I am on the brakes slowing down to a stop, or if I am on the brakes hard it will light up.
    Anyone familiar with this problem or know of a fix?
    Thanks!
  2. Oct 11, 2011 at 1:57 PM
    Tacoma Mike
    Southern Maine
    Check your brake fluid level in the master cyl. If you down around the add line stopping will uncover the sensor or turning corners may also and throw the light on.
    Might want to get your brakes checked as usually when it comes on your pads are worn down.
  3. Oct 11, 2011 at 7:59 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Thanks! Im at 72k so it probably is time for brakes, and I'll check my fluids too
