Parking Brake Lockup(?)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fastbolt, Dec 25, 2023.
  1. Dec 25, 2023 at 11:58 AM
    Fastbolt
    Fastbolt [OP] Active Member
    SW PA
    Underground 2025 Toyota Tacoma TRD Pro
    ReTrax Pro MX Bed Cover
    Just wanted to post this in case someone else experiences same.
    This afternoon I went to move my 2022 Tacoma Pro. 5200 miles on odometer. I was unable to move it forward. No trouble lights. There was power to the drive wheels but it felt like the brakes would not release. I don't set the parking brake when parking in my garage but use it when parking elsewhere. I started and stopped the Tacoma 3 times while trying to get the truck to move, to no avail. I repeatedly actuated and released the parking brake also. I managed to spin the tires just a little when applying the accelerator. I washed it yesterday but it has not been below freezing here in SW PA and in fact it is 61 degrees now.
    I decided to move the transmission selector between "forward" and "reverse" and try to "rock" the vehicle. It immediately seemed to break free and is running normally now.
    Still scratching my head on this one.
  2. Dec 25, 2023 at 12:00 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Did you wash the truck right before it happened?
    RIX TUX, Speedfreak and Chew like this.
  3. Dec 25, 2023 at 12:02 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Unfortunately a very common issue. Always drive your truck after washing to dry the brakes out, especially if you expect below freezing temps.
    Speedfreak likes this.
  4. Dec 25, 2023 at 12:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    normal, wet drums on these stick like a champ.
    try to heat them puppies up with some hard brakes, if you have to park after encountering water, or better yet, select a spot no parking brake is needed.
  5. Dec 25, 2023 at 12:04 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yep I’ve seen a thread or 2 on this issue before.
    I’ve never experienced it before myself, yet.
  6. Dec 25, 2023 at 12:27 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Wet brake shoes can and, over time, will fuse to the drum through rusting. It can even happen to disc brakes.
    I work on Commercial Transport vehicles in the Pacific Northwest and it is quite common with our wet weather. They park over the weekend and on Monday the brakes need to be broken free. And that's just from rain and moisture... not even washing them.
  7. Dec 25, 2023 at 12:43 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It has happened to me twice and neither time below freezing temps. The first time I used 4lo and eased it back and forth and until it let loose. The 2nd time I gave the wheel/tire a few really solid kicks until it freed up.
  8. Dec 25, 2023 at 2:09 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Only use parking brake when it is dry and problem solved.
  9. Dec 25, 2023 at 3:43 PM
    wayne0
    wayne0 Well-Known Member
    Parking brake??
