Parking brake question
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Feb 15, 2016.
  1. Feb 15, 2016 at 11:07 AM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    I bought a truck last month the parking brake never worked quite right because it needed adjustment at the frame. I recently rebuilt my rear end. And from lack of good help I took it to a Toyota dealer to get the brake fluid flushed. When I read did the rearend. I put new drum brakes wheel cylinders and brake lines and drums. I did not mess with the parking break at all. When I drove into the dealership the parking brake still didn't work well. I warned them that you have to leave it in gear so the truck won't roll away. After the brake fluid flush the parking brake works perfectly and the tech said he did not touch it. why would the parking brake work all of a sudden after a fluid flush. This is what perplexes me
    opteron likes this.
  2. Feb 15, 2016 at 12:38 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Sometimes a good technician will fix a minor issue and not say anything. I dont think the Toyota's E-brake is connected to the regular brakes. other than the springs in the drum. I believe they are interdependently moved...This is just my best guess.
  3. Feb 15, 2016 at 8:21 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    what probably happened was, you took your truck in for a simple service and mentioned a problem but didn't tell them to fix it. they wouldn't release the truck back to you knowing that you could easily get into an accident after leaving and then sue. the tech probably just fixed it and said he didn't touch it since it would be illegal for him to perform extra work without your knowledge and/or consent. plus it was probably trivially easy to fix for him :)
    you may have had the tech and manager shitting bricks though :rofl:
  4. Feb 15, 2016 at 8:39 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Haha thanks! Yeah it just needed adjustment at the frame and its been wet and cold so i never got around to it! i did warn them when i pulled it in to leave it in gear sobit wont roll away since it didnt work
