Parking brake replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by VirginiaBound, Dec 1, 2011.
  1. Dec 1, 2011 at 5:02 AM
    VirginiaBound
    VirginiaBound [OP] Whyareyoureadingthis?
    Sam I am, green eggs and ham
    North of Maine, South of Spain
    (Yes, I searched!)
    Has anyone dealt with the parking brake on a 1999 model? My brake cable separated and I've purchased another, I'm curious if it's something I can do at home or if I should let a shop do it.
    Any DIY or write up on this issue?
    Thanks! :rockband:
  2. Dec 1, 2011 at 5:37 AM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    U could do it yourself, my 93 broke and I changed myself, easy stuff to do. My was a 5 spd, dont know if the location for the automatic was the same. Some sockets and plyers is all you need, maybe a screwdriver, its been years. If you were closer I would help.
  3. Dec 1, 2011 at 5:40 AM
    VirginiaBound
    I've got a 5 speed, though I do believe the Auto's are the same deal.
    It looks like it's simply taking the old cable loose, routing the new cable in it's place and re-attaching and adjusting, correct?
  4. Dec 1, 2011 at 5:40 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    not the most fun to change but pretty easy, worst is probly conecting the cable under the dash
  5. Dec 1, 2011 at 5:56 AM
    VirginiaBound
    How do I un attach the existing cable from the handle? It broke right at the handle and all that remains is the metal piece at the end.
    The un attaching at the underside and removing the cable was a breeze. I tried turning the handle different ways and can't figure out how to gain access to the metal ball to remove it from the handle.
    Thank you for the help!
  6. Dec 1, 2011 at 7:20 AM
    GrayTacoma
    Andy
    Huntingtown, MD
    2011 TRD off road
    To be honest I dont remember too well, but I think you have to drop the handle after you take off a couple of panels. make sure u dont loose the retainer clips that hold the cable to the handle. have fun...
  7. Dec 1, 2011 at 7:23 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Yea my upper cable broke and i had to replace it. Cable part is easy. Its getting the acutal handle that is a MAJOR PITA and mother%@&*ing headache. But very doable at home.
  8. Dec 1, 2011 at 7:43 AM
    VirginiaBound
    I just got it finished up, it works great! I haven't had a parking break in over a year! :woot:
    Thanks again guys!
  9. Dec 10, 2011 at 2:13 PM
    01ToyTaco
    01ToyTaco New Member
    Germany
    01Tacoma SR3
    Lift kit,
    Does anyone have experience with parking brake cable replacement 01 Tacoma Ext Cab 4WD? My cable broke at the cable adjustment screw thread. Need to buy one, need to know the part number or proper description, then place an order in US since I am located in Germany. :confused:
  10. Dec 10, 2011 at 6:31 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    My parking brake hasn't work since I've had mine. Can't figure out why though, I've adjusted trying to get it working but nothing changes... Oh well :rolleyes:
  11. Dec 11, 2011 at 2:36 AM
    VirginiaBound
    Does it retain tension as you pull out the handle?
  12. Dec 11, 2011 at 3:01 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
  13. Dec 11, 2011 at 7:37 AM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    More than the wife knows!
    I replaced mine on my 01 ext cab. I got it from rock auto it wasnt that bad to replace but i found underlying problems like... the pivot adjusting arm was froze up and then found that the bell cranks were froze up as well so fixing these other issues made it harder than it would have been. BTW i have an auto so i think the PO never used it
  14. Dec 11, 2011 at 8:18 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    *AHEM*
    :eek:
  15. Dec 11, 2011 at 8:20 AM
    VirginiaBound
    :spy:
  16. Dec 29, 2011 at 1:49 PM
    01ToyTaco
    Germany
    01Tacoma SR3
    Lift kit,
    I purchased the parking brake cable from Rock Auto, after consulting with a Toyota Dealership Parts Department. The parts guy told me that OEM parking brake for Cable #2 was equivalent to Rock Auto "Dorman part C138655". I received the part couple of days ago from Rock Auto. Today, I was under my Toy to replace the old broken cable with the new replacement cable, just to find out that new cable is about foot short than the old cable pulled out from under the truck. When I called Rock Auto for an explanation, the service rep told me that it was made for standard cab and not extended cab, 4X4. Does anyone have the parts number, description, and/or parts store where I can buy one soon?
