Parking dad's 26ft trailer. 788lbs tongue weight
Discussion in 'Towing' started by Raceline08, Apr 14, 2013.
  1. Apr 14, 2013 at 8:12 PM
    Raceline08
    Raceline08 [OP] Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    I haven't done this. I really don't want to. I was curious of what you guys thought? I know the limits of the tacoma as far as tongue and towing weight. All this would be would be backing my parents 26 footer in to the barn, there are a lot of fences surrounding the opening to the barn so it would be ideal for a smaller rig (my truck) to park it. The 1 ton crew cab long bed diesel they have can't make the sharp turn into the barn.
    My question is should I even attempt this ? I don't want to brake my rig. Unloaded the trailer is 5525lbs. I would be backing up this trailer maybe 400 ft total.
    On a side note, my dad has been thinking about fabing an attachment with a ball so he could have the John Deere park it. I just don't know if the hydraulics could lift it?
    Any advice would be great .
    Thanks again,
    Brett
  2. Apr 14, 2013 at 9:45 PM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    I pulled a Kubota L39 and a 20 foot PJ 14k gvw on the 06 a little bit. Just up and down the street (now that was some tongue weight). I would do it, if I had to. But then again Im out of warranty;). We had a trailer ball attachment on the L39 and im putting one on the new(old) tractor too. Very handy unless you have a Kubota BX size tractor which wont lift 700lbs. What kind of Deere tractor?
  3. Apr 14, 2013 at 9:48 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    You should be fine for that short of a distance
  4. Apr 14, 2013 at 9:49 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    go for it
  5. Apr 14, 2013 at 10:03 PM
    Raceline08
    Brett
    Santa Rosa, ca
    ^ thanks for the input guys. I'm not worried I can't pull it but just the tongue weight. Almost 800 lbs seems crazy!?
    Thanks,
    Brett
  6. Apr 14, 2013 at 10:06 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Ill have to ask him not sure? It's a medium duty tractor for sure.
    Thanks,
    Brett
  7. Apr 14, 2013 at 10:24 PM
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    itll move it just fine, i made it 900 miles round trip with about 800 pounds tounge weight, plus all the gear iny truck pulling around 4500 pounds, your truck wont even care it hooked up to it!
  8. Apr 19, 2013 at 9:40 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Alright so I'm going to park this bitch. I'm most nervous cause I have the b110 shocks and haven't modified my bumpstops yet. ( the shock will bottom out before the dakars do) could have a shock blow out.
    That's my only real bitch. I'm going to go it anyway. Pops needs his trailer parked, and cause of his recent knee surgery he can't do it.
    On another note I was thinking of using 4 low for the reduction and less stress on the tacoma. What do you guys think?
    Thanks again,
    Brett
  9. Apr 19, 2013 at 9:44 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    what surface will you be moving the trailer on? i'd try 2-lo, but i'm not sure if theres a mod for it.
  10. Apr 19, 2013 at 9:54 PM
    Raceline08
    Brett
    Santa Rosa, ca
    I'm with ya, damn new rigs! No manual hubs like my 85' where I could choose that option. Damn new trucks. If I could get manual hubs I would but so far there is no aftermarket support for that on a 2nd gen.
    Flat level loose gravel is what I'll be moving the trailer on.
    Thanks,
    Brett
  11. Apr 19, 2013 at 9:59 PM
    95 taco
    95 taco Battle Born
    it sounds like 4-lo might work, if it starts binding put it back in 2, binding would do more damage than the clutches slipping in the tranny.
  12. Apr 19, 2013 at 11:06 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Ya I'm just still worried about the shocks.
    Thanks,
    Brett
  13. Apr 19, 2013 at 11:08 PM
    Raceline08
    Brett
    Santa Rosa, ca
    What do you mean about clutches slipping in the tranny? I don't know crap about automatics.
    Brett
  14. Apr 19, 2013 at 11:23 PM
    95 taco
    95 taco Battle Born
    i don't know alot about transmissions, but the way i understand it is when you put a manual in gear and the the clutch out, the engine and transmission are "locked" meaning any RPM change at the engine will be felt at the tires.
    Automatics use a bunch of clutches in the transmission instead of just one (or 2 depending on if the manual is a twin clutch system) when you have a auto in gear, the clutches are constantly slipping so the engine doesn't die while in gear.
    when you give the car some throttle the clutches start slipping less as they don't need to slip as much to keep the engine from dying.
    basically the clutches will keep slipping until you hit the right RPM, when you hit "the" RPM the torque converter locks up and acts like a manual transmission.
    i wasn't able to really explain it that well, i can tomorrow if you want, it's 1:30 so i'm not thinking 100%
    anyway, hope this helps.
  15. Apr 20, 2013 at 9:02 AM
    Raceline08
    Brett
    Santa Rosa, ca
    That makes sence
  16. Apr 20, 2013 at 8:44 PM
    Raceline08
    Brett
    Santa Rosa, ca
  17. Apr 20, 2013 at 8:46 PM
    Raceline08
    Brett
    Santa Rosa, ca
  18. Apr 20, 2013 at 8:48 PM
    95 taco
    95 taco Battle Born
    looks good.
  19. Apr 20, 2013 at 9:01 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Thanks man! Yea, 5525 lbs dry weight and a 788 lbs tongue was heavy.
    The tacoma handled it like a champ! I would not drive this down the road.
    ( I will not )
    Thanks,
    Brett
  20. Apr 20, 2013 at 9:04 PM
    Raceline08
    Brett
    Santa Rosa, ca
    If you had my rig would you pull something like that to go camp??? I know I'd have to get a brake box Etc etc etc.
    If I was into pulling this trailer I'd have air bags for sure.
    Thanks,
    Brett
