Parking Lights and Interior Lights Not Working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaff33, Sep 22, 2013.
  1. Sep 22, 2013 at 6:30 PM
    shaff33
    shaff33 [OP] Active Member
    Adam
    Harrisburg, PA
    06 Tacoma double cab
    Okay I need some help...
    Today I was rewiring a trailer and was using my 06 Tacoma to check the lights. I had two of the wires flipped so I was in the process of switching them and accidentally touched the wires. I heard a snap and figured that I blew a fuse.
    I checked all of the small fuses (7.5, 10, 15 and 20) that I could, but my parking lights and interior lights are not working. I am pretty sure that it is just a blown fuse, but where do I find the correct fuse at?
    or... is it something else?
    Any help would be sweet!
    Adam
  2. Sep 22, 2013 at 9:33 PM
    pinktaco808
    pinktaco808 Hot Steppa
    check for a short somewhere?
  3. Sep 22, 2013 at 10:34 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Interior fuse block is behind the change tray to the left of the steering wheel. The tail light fuse is in there.
  4. Sep 23, 2013 at 1:55 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This: ^^^ Should be a 10 ampere fuse.
  5. Sep 23, 2013 at 2:57 AM
    shaff33
    Adam
    Harrisburg, PA
    Thanks!!! Problem solved.
