Parking lights work with my brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96BlueTacos, Sep 3, 2020.
  1. Sep 3, 2020 at 7:09 PM
    96BlueTacos
    96BlueTacos [OP] トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    As the title suggests.... My parking lights come on, when I hit my brake lights. It’s like I have front brake lights.....might actually be kind of a cool mod, however this was not intentional at all. I used to have glitchy headlights and my parking lights would come on with the brakes.
    I swapped my headlight switch with a junkyard one. Was hoping it would fix both because I noticed both at the same time, assuming they were related. Headlights work fine now, but my parking lights still come on.
    I only switched out the lever on the headlight switch.
    am I just dealing with electrical gremlins that I have to chase down?
  2. Sep 3, 2020 at 7:15 PM
    slodoug
    slodoug Well-Known Member
    yep, sounds like a ground shorting. by "parking" lights do you also mean the rear as well as the marker lights in front or is it just the marker lights in front? if so, i'd inspect those connectors. see if it still happens when you disconnect each one.
    96BlueTacos[OP] and paetersen like this.
  3. Sep 3, 2020 at 7:18 PM
    paetersen
    paetersen Well-Known Member
    ^^^^^^yep. check your grounds.
    96BlueTacos[OP] likes this.
  4. Sep 3, 2020 at 8:00 PM
    96BlueTacos
    Mikey
    Ya Parking or marking Lights or whatever they’re called. I’m not sure about the rear, I haven’t noticed that. I never noticed “marker” lights in the back to be honest hahaha
    I had different issues In The 85 from a bad ground. I hoping, maybe this was a switch problem. Anyone know how many grounds there are to check on the truck?
    :frusty:
  5. Sep 4, 2020 at 12:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Check the light sockets where the brake and tail lights share the socket.
    If the tail lights are not coming on you have more problems.
    Unless your tail light harness has physical damage and the wires are touching
    96BlueTacos[OP] and TnShooter like this.
  6. Sep 4, 2020 at 12:14 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The parking lights get power from the tail light fuse.
    The tail lamp fuse gets power from tail lamp relay.
    The headlight switch activates the Tail lamp relay.
    The parking lights should not come on with the headlights in the OFF position.
    I’d pull the tail lamp fuse, press the brake pedal and see what happens.
    djm228, 96BlueTacos[OP] and DrZ like this.
  7. Sep 4, 2020 at 5:22 AM
    96BlueTacos
    Mikey
    Tail lights work and headlights work
  8. Sep 4, 2020 at 5:24 AM
    96BlueTacos
    Mikey
    awesome, that’s very helpful, I was looking the the FsM to try and find a similar breakdown.
    Parking lights only come on when I hit the brakes *if the headlights are off* if my headlights are on, obviously, the parking lights are already on
    everything else works just fine, and I recently noticed when I was parked In Front of some glass that those lights come on with my brakes
    Taco critter likes this.
  9. Sep 4, 2020 at 5:29 AM
    96BlueTacos
    Mikey
    Oh oh oh, you know, now that I’m thinking about it in those terms, the PO had wired up a trailer plug for brakes and everything to a trailer. I’m gonna poke around that wiring and see what’s going on. It was definitely a DIY wiring
  10. Sep 4, 2020 at 5:33 AM
    latchlock8111
    latchlock8111 Well-Known Member
    ... be 100% sure you have the correct size bulb in sockets. Have you recently changed out any ??
    96BlueTacos[OP] and Taco critter like this.
  11. Sep 4, 2020 at 7:15 AM
    96BlueTacos
    Mikey
    I had changed my turn signal bulbs probably over 3 years ago. I don’t think that this has been going on for that long. Last year or maybe 2018 my headlights started getting glitchy and around the same time I noticed the parking lights coming on when I hit my brakes
  12. Sep 4, 2020 at 7:16 AM
    96BlueTacos
    Mikey
    I’m gonna check the trailer hitch wiring, and then tail lamp fuse like was suggested. I’ll post what I find when i get it fixed
    TnShooter likes this.
  13. Sep 4, 2020 at 7:47 AM
    96BlueTacos
    Mikey
    So I noticed this morning on my way to work, my clock also dims down when I hit my brakes. But only if my headlights are off, same as my parking lights. Does this help in leading me towards a bad ground or a base fuse or relay?
    thanks for the help.
  14. Sep 4, 2020 at 12:40 PM
    TnShooter
    Deogee
    STOCK
    The clock is connected to a 10A Panel fuse.
    The Panel Fuse is also Powered by the Tail Light relay.
    The dimming may or may not be associated with your issue.
    I do believe however, you are on to something with the trailer wiring.
    Trailer running lights would be hooked to the tail lights.
    And the trailer brake lights would be hooked to the brake lights.
    I’d definitely start there.
  15. Sep 4, 2020 at 5:53 PM
    96BlueTacos
    Mikey
    thanks, thats good to know. Do you have a FSM? if you do you are obviously better at finding things in it than me :rofl:
  16. Sep 4, 2020 at 6:01 PM
    TnShooter
    Deogee
    STOCK
    No FSM, just an Electrical diagram (for a 99’)
    I some how got it off a link on a google search, from .AutoZone. of all places.
  17. Sep 5, 2020 at 6:57 AM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    I had this problem on 2 trucks over the years. Both the same problem— tow harness installer uses crappy connectors up behind the tail lights, the ground connector eventually breaks due to rot/corrosion. Trace the ground wire that begins at the brake/marker lamp socket on the assembly, you will find the problem quickly. Could be in either tail light. If you doubt it, hook a jumper from the socket shell to a good ground and your problem will (temporarily) go away. Second check- remove the bulb and it will also go away.
    Don’t waste your time with fuses and the switches/relays.
    TnShooter and 96BlueTacos[OP] like this.
  18. Sep 5, 2020 at 7:19 AM
    96BlueTacos
    Mikey
    Checking it out today, thank you. That will help in my searching for the connections that were made for the trailer harness.
  19. Jan 6, 2021 at 4:27 PM
    96BlueTacos
    Mikey
    well since it wasn’t a huge issue that my parking lights came On With my brakes, i hadn’t taken the time to start poking around the trailer harness hookup.
    With that being said, when I backed up to my house last night, I realized that my brake lights actually aren’t lighting up if I have my headlights turned on. If my headlights are off, my taillights(or brake lights, not sure) do light up when I hit my brakes, but so do the parking lights on the front.
    I’ve completely eliminated the trailer light harness and surprisingly it was done the proper way, with matching harnesses that plug into the OEM harness.
    I am at a loss as to why my lights are all jacked up.
    Any suggestions other than the trailer light doohickey?
  20. Jan 6, 2021 at 4:53 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    I would verify ground with a meter on all 4 marker lights, as well as the brake lights. This seems like a ground issue but I'd have to study the wiring diagram to be sure. Put one meter lead on the socket shell, and the other on a good frame ground/battery ground. Go through all the different lights on/off combinations and at all times the shell to ground voltage should stay close to 0 volts. If you are seeing things getting close to 12V, you know you have an issue. Problem could be at the shell or light connector, or could go all the way back to where the ground(s) for the lights ties to the body ground. These end up being at the kick panels if I'm not mistaken. There are 2 on each side.
