Parking lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devin1125, May 1, 2022.
  1. May 1, 2022 at 11:16 AM
    Devin1125
    Devin1125 [OP] Member
    2nd generation tacoma
    What is the color of the wire to tap into your parking lights I just got this new grill.
  2. May 1, 2022 at 11:18 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Green is power
    White/Black is ground
    It’s up to you if you want to tap into the Ground wire, or just use a body ground.
    I personally don’t like splicing into any more wires than needed.
    Otterstuff and Geeves77 like this.
  3. May 1, 2022 at 12:23 PM
    Devin1125
    What wpuld be my headlight tap then bc my parking light won't turn it on
  4. May 1, 2022 at 12:31 PM
    TnShooter
    Deogee
    STOCK
    Low beam is Red/yellow or Red/Black depending on what side you are tapping into.
    I don’t see why Parking lights won’t turn it on?
    Do the parking lights work?
    They are powered by the Tail fuse.
    Otterstuff likes this.
  5. May 1, 2022 at 12:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Use a DVM to test.
    Then disconnect the battery ground and do your work.
    Reconnect your battery ground and test your work.
    TnShooter likes this.
  6. May 1, 2022 at 12:38 PM
    TnShooter
    Deogee
    STOCK
    Or use a test light. That way you know you have the ability to carry current.
    I still think the parking lights are a better option. Mostly because when using the headlights, the light will be on of off depending on whether you to tap to the Hi or Lo beam.
