Parking Ligts(Lights ext to the main headlight)
Discussion in 'Lighting' started by frankygomez01, Nov 23, 2010.
  1. Nov 23, 2010 at 10:42 AM
    frankygomez01
    frankygomez01 [OP] Rolling Low And Smashing Hard
    Franky
    Under A Roof
    2000 Tacoma Single Cab
    K&N Intake, Black 18" Kyowa racing rims, 6 inch drop kit
    I cannot figure out how to take it off, my bulb burned out and i cannot figure out how to pop off the light. PLZ help
  2. Nov 23, 2010 at 10:47 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Should just unscrew from the headlight assembly. Counter-clockwise, then there's usually a retainer clip holding the bulb itself to the wiring harness that is easily undone with a small flat-head screwdriver.
  3. Nov 23, 2010 at 10:50 AM
    frankygomez01
    Franky
    Under A Roof
    is the screw the only thing holding it down, or is there another clip inside?
  4. Nov 23, 2010 at 10:56 AM
    Pugga
    Massachusetts
    F-150 Mod
    The whole bulb and harness should unscrew from the headlight assembly, not an actual screw. Once you've got the bulb and harness out of the headlight, there's usually a plastic retainer clip holding the parking light bulb to the harness preventing you from just pulling the two apart. What year is this for, I'll see if I can find a picture for you?
  5. Nov 23, 2010 at 10:59 AM
    frankygomez01
    Franky
    Under A Roof
    it is a 2000 tacoma
  6. Nov 23, 2010 at 11:06 AM
    frankygomez01
    Franky
    Under A Roof
    so just pull until it comes out
  7. Nov 23, 2010 at 11:19 AM
    frankygomez01
    Franky
    Under A Roof
    k thanks guys i got it off and just need to buy the bulb, can i get ut at autozone?
  8. Nov 23, 2010 at 11:23 AM
    Pugga
    Massachusetts
    F-150 Mod
    Yep, any auto parts store, autozone or advanced auto. Sorry for the mix-up, I assumed you had 2nd Gen:eek:, they just unscrew, no bolts, clips, etc. Glad someone was able to help you out before got you thoroughly confused!
  9. Nov 23, 2010 at 11:26 AM
    frankygomez01
    Franky
    Under A Roof
    haha its ok but thanks anyways appreciate the help :)
