Parking on slight incline in 1st gear w/no e-brake
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Dec 20, 2011.
  1. Dec 20, 2011 at 7:46 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    So my e-brake has been sticking lately in super cold temps.
    My driveway is on a slight angle and I've been parking the truck in 1st gear with no e-brake.
    Is this bad for the transmission at all? And is parking with the front of the truck at the top of the incline better/worse than at the bottom of the incline?
  2. Dec 20, 2011 at 7:56 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    I've heard that resting on the tranny is bad and ive heard that it isn't. I always use my ebrake tho my dad doesnt and his car seems to be just fine. Your can always put blocks or a few sand bags behind your tires to take the weight off the tranny.
  3. Dec 20, 2011 at 7:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    I always used 1st (left in gear) on both my first gen and pickups.
  4. Dec 20, 2011 at 8:07 AM
    Madjik_Man
    With the e-brake off?
    I always leave it in gear with the e-brake on, but I feel weird about leaving it in gear without the e-brake on
  5. Dec 20, 2011 at 8:08 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    In gear on a manual is fine with no e-brake. Watch out for little kid or dog knocking out of gear.
    Turning wheel or getting wheel chucks or firewood not a bad idea so you don't have to go looking for your truck at the bottom of the hill.
  6. Dec 20, 2011 at 8:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    No e-brake.
  7. Dec 20, 2011 at 8:14 AM
    Madjik_Man
    Selkirk, NY eh?
    I had a one week fling (about 25 years ago) with a girl from Selkirk. It was very Grease (Sandy and Danny) like, minus all the machismo lying, etc... Man she was really nice, cool, beautiful...
    Wonder what, she's doing now...?
  8. Dec 20, 2011 at 8:39 AM
    wmdpowell
    Bill
    Essex county NY
    Small world sometimes. I've only been in this town (bethlehem) about 15 years.
  9. Dec 20, 2011 at 8:54 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Without the parking brake, you rely on engine compression for holding the truck in place. There is a parking pawl which locks the flex-plate on automatics, there is only the parking brake on manuals.
    Trust your engine to hold you at your own risk. It won't do any damage, unless it starts rolling.
  10. Dec 20, 2011 at 3:42 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    get that shit fixt.
    E stands for "Emergency"... just sayin'
    try greasing the cable and pivots with some low temp grease.
  11. Dec 20, 2011 at 6:59 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    But that's a misnomer. It is technically called a parking brake. Using it as an emergency backup to the main brakes is possible, but tends to lock up very easily.
  12. Dec 20, 2011 at 7:03 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    The only time I use my e-brake is when I get out of the truck when it's running. I always park it in gear only. When the truck is flat or facing uphill, I use first. When facing downhill, I use reverse. I have done this to both my Tacomas and never had a problem so far. If the hill is steep I've also been known to use low range as a parking brake.
  13. Dec 20, 2011 at 7:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This.
    For a long time I thought that engine compression only would hold a vehicle on a steep incline. Only recently did I learn the truth. Thankfully I did not find out the hard way. But believe me, if the hill is steep enough the engine WILL turn over and the truck will roll.
    If it does start rolling in gear and causes the engine to turn backwards, that may hurt something (besides the body work), not sure.
  14. Dec 21, 2011 at 7:49 AM
    jbrandt
    Justin
    Well duh, if you are trying to use the E brake to stop faster, you deserve the Darwin award you will inevitably be awarded.
    The "Emergency" is if your shifter pops out of gear, and the truck rolls away.
    That constitutes an emergency.
    Just get the E (or P) brake fixed so it works in the conditions you live in. People in Alaska, North Dakota, etc... all have working parking brakes.
  15. Dec 21, 2011 at 8:41 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    very slight hills are ok, but if it's steep at all, don't trust that it won't roll away.
  16. Dec 21, 2011 at 8:52 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    4lo for more security more frozen diffs to keep it from rolling:p
  17. Dec 21, 2011 at 9:00 PM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    In very cold weather drum brakes can stick when left engaged for long periods. Since your emergency brake engages those only, you take the risk of having them stick when engaged overnight. There's no "fix" I know of for preventing that.
  18. Dec 22, 2011 at 3:44 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    There's two methods. Rock the truck back and forth, or tap the drum with a hammer. Don't try the second one when parked on a hill:eek:
  19. Dec 22, 2011 at 4:04 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    This is how I got my last truck for 400 bucks. Owner never fixed his parking brake. He parked on a slight incline, it rolled down the slight incline to the larger incline and rolled over. I'd suggest chocks if you want to prevent this from happening.
  20. Dec 22, 2011 at 4:07 AM
    MQQSE
    MQQSE Bannable Galloot
    Rob III
    Palmer, Alaska
    "Stitch" Still Stock Concept Truck
    Shtuff
    Mine works because I don't use it in winter...pretty common practice to not use the parking brake up here. Took me a little while to get used to it. And I've had manual trans vehicles 8 of the 10 years I've lived here.
    What he said!
    I would be concerned parking on an incline in winter ... even with the parking brake set the vehicle could slide in icy conditions. I've actually seen a C17 cargo aircraft push it's chocks and slide a few feet with only a slight incline; and the acft was shut down with nothing going on...just parked on the ramp. But it was icy when the acft blocked in. Cold and ice do funny things to pavement/rubber/wood/metal. EDIT: I should add high winds were involved in moving the acft, but I feel the point is still valid.
    I guess what I'm saying is to consider some kind of chocks if parked on the incline is your regular parking spot. But even chocks won't guarantee it won't slide down hill. The wheels don't have to turn for it slide on ice. FWIW :notsure:
