Parking Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mtcarrio, Apr 8, 2012.
  1. Apr 8, 2012 at 5:20 PM
    mtcarrio
    mtcarrio [OP] Active Member
    New Orleans
    2007 TRD Sport
    Skid plate, debadged
    Hey everyone,
    I was driving my tacoma today no problems. I drove home however and parked the truck normal. Get back in the truck and the gear shifter will not come out of park. Eventually I am able to get it out of park by literally banging it to the right so that i could drop it into R and other gears. I drove around a while and then parked it again, same trouble removing the truck from park.
    Any ideas????????
  2. Apr 8, 2012 at 5:24 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Are you parked on a hill?
  3. Apr 8, 2012 at 5:24 PM
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    There is usually a "park release" fuse of sorts. I blew one in my sisters car once upon a time by grounding out the license plate.... dont ask, that car was ghey
  4. Apr 8, 2012 at 5:26 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Most likely the brake switch above the brake pedal.
  5. Apr 8, 2012 at 5:26 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Do you set your parking brake? Set parking brake then put transmission into park. You may have a crappy connection somewhere or faulty brake switch. When you press your brake pedal, you should be able I hear the shift interlock disengage. Are your brake lights working well?
  6. Apr 8, 2012 at 5:37 PM
    hogeyphenogey
    Dave
    Agawam, MA
    Get a new brake switch, they are usually very inexpensive. You can also take yours out and check it to see if it is moving freely. It's the usual cause for this. The switch fails so the truck doesn't know you're pushing in the brake pedal to shift
  7. Apr 9, 2012 at 4:03 AM
    mtcarrio
    New Orleans
    2007 TRD Sport
    Thanks for the quick response, aewsome site/members.
    Im on flat land. i will check the fuses, which location would a brake fuse be in. Not sure if my lights are working, but i assume they are. Regarding the brake switch, where do i find that/check it?
