Parking vehicle for 3 months
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tbrooks2444, Mar 2, 2020.
  1. Mar 3, 2020 at 11:46 AM
    #41
    Tbrooks2444
    Tbrooks2444 [OP] Well-Known Member
    Intense. I like it!
  2. Mar 3, 2020 at 11:46 AM
    #42
    Tbrooks2444
    Thank you all for the help!
  3. Mar 3, 2020 at 12:43 PM
    #43
    Duezzer
    Duezzer Well-Known Member
    Glenn
    2019 Cavalry Blue TRD Sport
    Some - Will list later - has lift and new wheels and rubber
    That is full out done to a T. Nice.
  4. Mar 5, 2020 at 4:54 PM
    #44
    JK2TACOma
    JK2TACOma Well-Known Member
    Michigan
    19 TRD Sport DCSB Super White
    Sliders, Roof Rack, Bed Rack, Clear Coated Frame(diy) & Waxed Alot!
    I have had great luck with cologne or perfume. mice have super sensitive noses and are unable to endure a powerful smell. If you can smell it mice cannot endure it.. Spray on tires and they cant/won't be able to enter vehicle
    Big tall dave and six5crèéd like this.
  5. Mar 5, 2020 at 6:05 PM
    #45
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    If I did that my wife wouldn’t get in it either o_O
  6. Mar 6, 2020 at 12:06 AM
    #46
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    sometimes they sit dealer lots that long
    sometimes longer
    Stabil in a the gas is the best precaution
    make sure ALL other fluids Correct !!
    use a Battery Tender if at home or garaged
    not unusual a good battery will lose approx 5% each month
    otherwise U cant stop time
  7. Mar 6, 2020 at 2:56 AM
    #47
    itsmermf
    itsmermf Well-Known Member
    Robert
    Merritt Island, FL
    2017 Tacoma TRD PRO
    Interior LEDs, all weather mats, TRD performance CAI, trifold hard tonneau cover, predator pro step, accessory interior/exterior illumination package. Kicker tweeters, Kicker speakers.
    Definitely protect against rodents, start by getting a ball of thick steel wool, remove your engine air filter, feel for the air intake opening and plug it well. Make sure you use a checklist do you don’t forget to remove it when you’re ready for the road again, or place your air filter on the drivers floorboard as a reminder.
  8. Mar 6, 2020 at 3:06 AM
    #48
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I’m a Merchant Mariner, I’m used to 10 week hitches. I live in NC, work out Louisiana. Ive been doing it for years, only came out to a dead battery once due to leaving my interior camper shell light on. Truck starts up every time and drives me 700+ miles. My only concern is parking somewhat near the ocean due to my occupation but in my case the surface rust is minimal even for my 1st gen.
  9. Mar 6, 2020 at 3:07 AM
    #49
    JK2TACOma
    Michigan
    Spray cologne or perfume on the tires and be done..
  10. Mar 6, 2020 at 3:25 AM
    #50
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Set the climate control to recirculate to close the flap so rodents can't climb in.
    I'd be a little worried about poison if there are any cats or dogs around.
    You can disconnect the battery so the ECU, clock and radio don't drain it over time. Or pull the corresponding fuses. Usually, DOME fuse provides power for the radio presets and clock, but you'd have to check the wiring diagram. This is if you have to leave it outside and can't easily keep a trickle charger in it. You could get a solar trickle charger and wire it from the inside.
  11. Mar 12, 2020 at 12:39 PM
    #51
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    Sounds like youre more worried leaving the truck than the wife. Brush off some of that salt on your shoulders you salty dog
    Be safe on deployment :oldglory:
  12. Mar 12, 2020 at 12:51 PM
    #52
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Run you gas tank down as low as you can get it then fill up with NON-Ethanol gas.
  13. Mar 12, 2020 at 1:10 PM
    #53
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    My motorhome parks in my backyard for almost 8 month every years. I try to start it once and a while but it regularly goes month without running. I remove the battery cables and put a Noco gen 2 battery maintainer on them. I have done this for the last 15 years that I have owned it and it did the same for 15 years my father owned it. I have never had a tire flat spot. I have never had lubricating issues. The gas might smell a bit when I first fire it up but I run a little stabilizer and a fresh tank and she is good as new. A couple rodent issues that likely were minor with no wiring damage. 3 months is nothing.
