Part # for Denso Spark Plugs (2005 2WD)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaliforniaTaco, Aug 29, 2010.
  1. Aug 29, 2010 at 12:48 PM
    CaliforniaTaco
    CaliforniaTaco [OP] Well-Known Member
    Having a hard time finding the part # for the correct set of Denso spark plugs (after reading a few forums I was advised not to use any spark plugs but these). I have a 2005 4cyl 2WD Tacoma, I think the engine is a 2TR-FE(?)
    I guess I should add that I don't know which is the proper plug based on Denso's website:
    2005 TOYOTA TACOMA 2.7L 2TRFE IKH20 Iridium Power
    2005 TOYOTA TACOMA 2.7L 2TRFE K20HR-U11 Resistor Plug
    2005 TOYOTA TACOMA 2.7L 2TRFE PKH20TT Platinum TT
    2005 TOYOTA TACOMA 2.7L 2TRFE SK20HR11 Iridium Long Life
    Thanks!
  2. Aug 29, 2010 at 1:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Aug 29, 2010 at 1:21 PM
    CaliforniaTaco
    thank you SO much
  4. Aug 29, 2010 at 1:22 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
