Part/Lever on Rear End Housing
Discussion in '1st Gen. Tacomas (1995-2004)' started by lougar, Feb 12, 2016.
  1. Feb 12, 2016 at 2:24 PM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    18 Silver Tacoma TRD 4x4 Offroad. Crawl & MTS. 06 Blue TRD Tacoma Sport 4x4.
    Apologies for the dumb question, but I just purchased an 01 Prerunner. Great little truck. Had to adjust the emergency break, and while working underneath the rear end, I was wondering what that lever thats to the right of the rear end casing is. Attached to what looks like a hydraulic line, but doesn't seem to be associated with the breaks. This is not a 4WD. Can anyone chime in? Is this some kind of differential lock on the 2WD? Appreciate any feedback.
  2. Feb 12, 2016 at 2:28 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did it look like anything in the pic I posted? I'm gonna guess the per-portioning valve.
  3. Feb 12, 2016 at 2:40 PM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    Not sure thats it. I have a stock pic (not mine).
  4. Feb 12, 2016 at 3:00 PM
    koditten
    Kirk
    Central Michigan
    Yep, load sensing proportioning valve.
    The more weight in the bed the lower the bed sits, makes more braking action when having to stop heavier than normal load weights. More weight in the bed =more braking action needed to stop the truck.
  5. Feb 12, 2016 at 10:08 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Thats not the valve itself, but what the diagram refers to as a 'shackle' that allows connection of the LPV to the axle.
  6. Feb 13, 2016 at 5:18 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Just reading and learning. So, I guess if you have sagging leafs as many Tacos do this would screw up your braking even when the bed wasn't loaded?
  7. Feb 13, 2016 at 8:21 AM
    tan4x4
    Rick
    Folsom, CA
    I wouldn't say that it screws it up. It would slightly increase the braking force to the rear wheels, as its supposed to do.
    However, if you notice the rear wheels skidding under moderate braking, then that would be an issue to addess.
  8. Feb 16, 2016 at 6:53 AM
    lougar
    lougar [OP] Member
    Luis
    Mobile, AL
    Thanks for the replies. I now also know what to look for if there is a problem with it.
  9. Feb 16, 2016 at 11:20 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    the most basic analogy is like the old toilet bowl floats, as the rod moves it allows fluid to flow, the more it moves the more braking pressure is applied to the rear drums.
    our trucks are so damn light that for safeties sake, you are supposed have little to no rear brakes at all unless the bed is weighted down. it has to be that way or any abrupt applying of brakes would cause the rear end to slide around and do a 180 in the road.
