Part number or replacement for adjusting bolt, 2rz-FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fishball Squeak, Dec 25, 2021.
  1. Dec 25, 2021 at 6:10 PM
    Fishball Squeak
    Fishball Squeak [OP] Member
    Appalachia
    2000 5 lug 2rz Tacoma
    Diff Breather Mod
    Went to change my belts and snapped the adjusting bolt for the water pump pulley (apparently I didn’t use enough PB blaster) on my 2rz. Anyone have a part number or recommendation for a replacement bolt?
    Any recommendations on how to get the snapped bolt out? Thinking about using an easy out but I’m worried I’m gonna have to pull the motor due to lack of wiggle room to use a drill and bits.
  2. Dec 25, 2021 at 6:55 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  3. Dec 25, 2021 at 6:59 PM
    Fishball Squeak
    Appalachia
    Diff Breather Mod
    Looks extremely close although it looks to be for a different engine, although I’ve done the differential breather mod and that called for a part from a Camry. If I can’t find anything else I’ll get this and report the results.
  4. Dec 25, 2021 at 7:01 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Just making sure, you did loosen the locking bolt?
  5. Dec 25, 2021 at 7:06 PM
    Fishball Squeak
    Appalachia
    Diff Breather Mod
    It was the adjusting bolt for the power steering belt, not the alternator, unless I goofed up and the bolt for the pulley is also the locking bolt, which I admittedly did not loosen as I’m a bit inexperienced :/
  6. Dec 25, 2021 at 7:20 PM
    Wsidr1
    Indiana
    Okay, your first post says it's the water pump pulley.
  7. Dec 25, 2021 at 7:27 PM
    O'Silver_Taco
    MD
  8. Dec 25, 2021 at 7:31 PM
    Wsidr1
    Indiana
  9. Dec 25, 2021 at 7:33 PM
    Fishball Squeak
    Appalachia
    Diff Breather Mod
    Ah yeah my bad, I was using a belt diagram for a 2002-2006 Tacoma from autozone. It’s the power steering pulley/belt, and I did forget to loosen the locking bolt. Guess my young age and inexperience with engines is showing haha.
    The bolt kit linked above does indeed work for the alternator on the 2rz, so I guess I’ll hope they can be swapped around, as I can’t find anything else. Will be interesting because I know the power steering pump bolts are 14mm and the alternator bolts are 12mm. Might try out the scrapyard first though.
  10. Dec 25, 2021 at 7:37 PM
    O'Silver_Taco
    MD
    So this is it?....
  11. Dec 25, 2021 at 7:38 PM
    Fishball Squeak
    Appalachia
    Diff Breather Mod
    Spot on
  12. Dec 25, 2021 at 7:47 PM
    O'Silver_Taco
    MD
  13. Dec 25, 2021 at 8:04 PM
    Fishball Squeak
    Appalachia
    Diff Breather Mod
    Seems to be right!! I’ll give an update on fitment in the next few days. Thank you!!
  14. Dec 25, 2021 at 8:15 PM
    O'Silver_Taco
    MD
  15. Dec 25, 2021 at 9:57 PM
    Fishball Squeak
    Appalachia
    Diff Breather Mod
    That bolt goes to whatever is in this, not the idler pulley. The OEM adjusting bolt is apparently M8-1.25x 90mm with a 14mm head.
    Dorman makes a replacement for the entire pulley that’s 23$ vs the 200$ for OEM. I figure I’ll buy that and take the bolt from it and have some spare parts if I decide to break it some more :thumbsup:
    https://www.amazon.com/gp/aw/d/B00GHTEDCY#Ask
  16. Dec 26, 2021 at 10:24 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    i have made many of these using the correct all thread and welding on a nut. Looking around it is also possible to find a fully threaded bolt of the correct size I have bought a few of these over the years they come in handy.
    I would not try with this still attached to the engine not having a 4cylinder handy to look at does not help
    can you get the adjuster off the engine without pulling the engine ?
    Maybe pull the radiator .
    Best of Luck.
