Part Out! Available now - Wheels, suspension, sliders, spacers, tonneau cover, lights
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by itsthex, Nov 8, 2023.
  1. Nov 8, 2023 at 8:24 PM
    itsthex
    itsthex [OP] Well-Known Member
    Cory
    2020 Tacoma TRD OR DCSB
    17" TRD SEMA wheels w/ 265/70R17 Nitto Grappler G2
    Hey guys! All of these parts are off the truck and are now for sale. Don't hesitate to reach out.
    I can also offer checkout through PayPal so you can use their available PayPal financing options for the expensive stuff.
    ALL PRICES OBO
    Located in Inland Empire, CA
    Here's a few shots of the truck for reference.
    Instagram-CiM-Tacoma-Lytle-Creek-Divide-6134.jpg Instagram-CiM-Tacoma-Lytle-Creek-Divide-6153.jpg
    Parts and prices:
    SOLD Locked Offroad full 2.5" extended travel coilover kit (front and rear, stock replacement) - $SOLD
    - Great performing kit, comparable to FOX
    - ~3,000 miles
    - 650 lb springs, ride height set for stock weight (~2.25" lift in front)
    - No wait, available now
    https://www.lockedoffroad.com/collections/3g-tacoma-2016/products/toyota-tacoma-2-5-shock-package
    SOLD Accutune Tubular Spherical Front UCA's - $SOLD
    - Perfect condition
    https://accutuneoffroad.com/product...H_yZuu7OXuOmDkMZVg-zMVVKc9cSQUD4aAk4FEALw_wcB
    SOLD Accutune N98 (J66 hybrid) leaf pack - $SOLD
    - Bushings still in excellent condition
    - ~2.25" lift on stock weight truck
    - Rides like stock but slightly softer, good for stock weight or +300lb/towing
    https://accutuneoffroad.com/product/deaver-n98-2-lift-leaf-springs-05-up-tacoma/
    SOLD Accutune U-Bolt flip with Progressive bump Stops - $SOLD
    - Bump stops in perfect condition
    - Height set appropriately for this setup (can be changed, contact accutune)
    https://accutuneoffroad.com/product/accutune-offroad-u-bolt-flip-kit-05-toyota-tacoma/
    4 Wheel Parts Heavy Duty Rock Sliders with Kickout - $500
    - Light scratches from bushes, etc
    - Never touched a single rock
    - Excellent condition
    (4) BORA 1" Bolt-on Wheel Spacers - $125
    SOLD (4) Spidertraxx 1.25" Bolt-on Wheel Spacers - $SOLD
    SOLD Bakflip F1 Tonneau Cover - $SOLD
    - Perfect condition, all hardware included and not damaged
    - Bolts straight in, no modification to the truck needed
    - Relocates factory tie-down bars so they can still be used
    - Holds up to 400lbs on top of cover
    https://realtruck.com/p/bakflip-f1-...eYx2l6Rbl4LEWtfy2HUguCj1iehuYmy8aAgcbEALw_wcB
    SOLD Diode Dynamics SS3 Fog Lights - $SOLD
    - Direct bolt in
    - 1 repaired bracket
    - Amber, DOT Approved (won't blind everyone on the road, still works amazing offroad)
    https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2016-2023-toyota-tacoma.html
    SOLD Cali Raised Hidden Light Bar Brackets with Light Bar - $SOLD
    - Will come with all wiring and necessary hardware
    - High Quality Amazon brand lightbar (Spot focus center lights, spread outer)
    https://caliraisedled.com/products/2016-2021-toyota-tacoma-32-lower-bumper-hidden-led-light-bar-kit
    SOLD (2) Trigger One Bluetooth Relay - $SOLD
    - Directly replaces most light and accessory relays
    - Allows control of accessories via bluetooth on your phone!
    - Removes necessity to run wiring and switches in the cab (clean install)
    (4) Classic 1997 spec Rays Power Volk 2pc wheels (16x7, +25 offset) with Yokohama Geolander 255/85r16 tires @ 50% tread (plus one spare unmounted tire, same size) - $2500 OBO
    - Ultra light, similar to modern Rays Volk wheels at 16.5lbs
    - Practically unattainable in this color and condition
    - Fully restored, all new hardware
    - Same as stock wheel offset on 3rd gen, but needs at least 5mm spacer to clear brake calipers
    - If using 5mm spacer, shouldn't rub at all on cab or chassis!
    - Currently setup on truck using 1" spacers as seen in photo
    Instagram-CiM-Tacoma-Lytle-Creek-Divide-6084.jpgIMG_8631.jpg IMG_8656_jpg.jpg
    SOLD 3rd Gen OEM Tacoma 5' Bed Mat - $SOLD
    (2) 12" Kartek Offroad Limit Straps with Clevis - $100
    (2) Kartek Offroad 10" Limit Straps - $50
    (2) Trail Gear 8" Limit Straps - $45
    5150 Whips 4' 187 LED Whip w/ Tacoma Bed Mount and controller - $150
    - Cascading lights, music match, etc
    - Mounts directly to the right rear of tacoma using factory bolts
    https://5150whips.com/collections/whips/products/1x-187-led-whip
    Morimoto Plug-and-Play HID Kit w/ LED High Beams and Amber Blinkers - $125
    (24) Rays L42 Dura Lug Nuts - $125
    Thanks for looking!
    SUMOTNK and Kefka like this.
  2. Nov 8, 2023 at 9:25 PM
    TRDMobile4x4
    TRDMobile4x4 Well-Known Member
    Nathan
    2019 Cement Grey Tacoma TRD Off-Road
    I am interested in your lights you are selling, both the fogs and the light bar
  3. Nov 8, 2023 at 9:26 PM
    TRDMobile4x4
    Nathan
    Also how is the Bluetooth relay for the lights, does it run the hidden light bar?
  4. Nov 9, 2023 at 11:12 AM
    sarcastictechsupport
    sarcastictechsupport Well-Known Member
    SoCal (805) - Mohave Desert
    2020 Super White TRD OR
    Potentially interested in UCAs. How many miles are on them?
  5. Nov 9, 2023 at 12:40 PM
    TheProject
    TheProject GorillaTaco
    Southern California
    2022 TRD OR DCLB - Midnight Black
    Interested in bump stops. How many miles have you put on since installed?
  6. Nov 9, 2023 at 3:27 PM
    rip ej1
    rip ej1 Well-Known Member
    Daniel
    NorCal
    2020 AG TRD Pro
  7. Nov 9, 2023 at 5:36 PM
    itsthex
    Cory
    Ok, I will let you know once I decide to move ahead with sale. Bluetooth works perfectly with the lights and that's how it is currently installed.
    Miles are the same as suspension, ~3000. Only been off-roaded about 4 times since install, the rest are highway.
  8. Nov 9, 2023 at 10:28 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Those wheels! :drool:
    itsthex[QUOTED][OP] likes this.
  9. Nov 11, 2023 at 12:07 AM
    j10munoz
    j10munoz Well-Known Member
    Jacob
    2018 Toyota Tacoma White SR5
    Window Tint
    Located in Riverside and intersected in the tonneau cover!
  10. Nov 13, 2023 at 10:48 AM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    @LivinOnEdge
  11. Nov 13, 2023 at 3:31 PM
    itsthex
    Cory
    Thanks for all the interest guys. Still hoping to sell suspension first before deciding for full part out. Stay tuned. bump bump.
  12. Feb 5, 2024 at 6:38 PM
    itsthex
    Cory
    Bumping this to the top! Everything is now available. I'll be updating the thread with more pics later this week.
  13. Feb 6, 2024 at 9:13 AM
    OG_Tacoma
    Is the light bar meant to be plug & play, or hard wired?
    Willing to sell u bolt flip kit separate (from bump stops), or nah?
  14. Feb 6, 2024 at 12:06 PM
    itsthex
    Cory
    light bar connected directly to battery and has a switch. The flip kit and bump stops work directly together, it’s a proprietary kit
  15. Feb 6, 2024 at 7:19 PM
    Manwithoutaplan
    ID
    nice rims
    itsthex[OP] and TXpro4X4 like this.
  16. Feb 10, 2024 at 10:51 AM
    itsthex
    Cory
    Tonneau cover is sold! Everything else still available.
  17. Feb 10, 2024 at 3:15 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Parts need to be off of the truck or mods may take it down. I would take some more photos too of all of the parts GLWS/free bump
  18. Feb 12, 2024 at 2:00 PM
    itsthex
    Cory
    Added photos, OEM Bed Mat, 5150 Whips LED whip, HID kit, Rays Lug Nuts and limit straps to the sale.
    All prices OBO.
    AmateurTaco1313 likes this.
  19. Feb 15, 2024 at 3:21 PM
    Ironside
    Ironside Well-Known Member
    2017 TRD Sport DCLB 4x4 - MGM
    - Alpine iLX-F509 head unit - Borla ProXS 40665 muffler - Clazzio black leather seat covers - Diode Dynamics SS3 Sport Fog Lights (yellow) - Hurst T-Handle shift knob - MESO v2 Ultimate Dome Light - Method NV 305 black wheels (17x8.5, 0 offset) - "Poor man’s CAI" (intake flow accelerator PTR03-35160-AE + HPS performance intake hose + aFe Pro-Dry S Air Filter) - Spotter mirrors - Subaru Kicker tweeters - Toyota Black Chrome exhaust tip - TRD Off Road shocks - TRD Pro grille - TRD skid plate - VIOFO a119v2 dash cam (set up with fuse tap) - Window tint 20% - Yokohama Geolandar G015 tires (265/65/17) - Ziebart Rust Protection (frame coating)
    Which DD Fogs? Sport?
    Are you willing to ship?
  20. Feb 15, 2024 at 7:15 PM
    itsthex
    Cory
    Sorry, fogs are sold!
    U bolt flip / bump stop kit and leaf springs are also now sold.
    Updated/reduced pricing for a few things.
