Part time hard start issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter gatherer, Apr 17, 2021.
  1. Apr 17, 2021 at 5:51 AM
    Hunter gatherer
    Hunter gatherer [OP] Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    2013 V6 with 130000 KM . My truck starts fine most of the time. Lately at the end of my work day when I first try to start it I have to crank it a lot,less than 5 seconds. So far this only occurs at the end of my work day after the truck sits the whole time. First thing in the morning it starts fine,if I shut it off after a hard start it starts fine. Is the truck trying to tell me to get a new job?
    Toyko Joe likes this.
  2. Apr 17, 2021 at 6:03 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I'd start with the simple things, job change, spark plugs, MAF sensor clean, new air filter, maybe run some Techron through the gas.
    When were the plugs last changed? How far do you drive daily? What's the general mechanical condition of the truck?
  3. Apr 17, 2021 at 6:26 AM
    Hunter gatherer
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Plugs have about 42000 KM on them( getting close so I'll put new ones in), during the week I drive about 30 KM a day, I don't abuse the truck so mechanically its in good shape. The things you mentioned I'm planning to do this weekend, just confuses me why it starts fine except at the end of my work day. Thanks for your response I now have my shopping list in hand. Start with the basics first I guess.
  4. Apr 17, 2021 at 6:45 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    you say end of day but is that a day of running around or sitting in a lot for 8 odd hours so it cold but warmer than when you started in the morning to go to work?
    makes no sense but just trying to understand
    Lefthook and blu92in99 like this.
  5. Apr 17, 2021 at 7:06 AM
    Hunter gatherer
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    CraigF, this is after it sits at work for 10 hours. Problem just started up so trying to diagnose it. I'll try to update with what I do but that won't be till Tuesday when I'm back at work. This weekend will be plugs ,air filter and such.
  6. Apr 17, 2021 at 7:09 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Dirty MAF and TB are usually to blame for a hard start like this. When my work truck, GMC sierra 1500, does exactly as you describe, I know it's time to clean the MAF & TB, then it starts just fine.
  7. Apr 17, 2021 at 7:12 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Bless you, for actually trying to understand the issue...instead of being like everyone else:
  8. Apr 17, 2021 at 7:18 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Sometimes as vehicles get a bit older the fuel will drain back a bit when sitting for a long time. Try this:
    Turn the key to the on position and wait until you hear the fuel pump stop running, then turn the key further to crank the engine.
    Also try doing the above but turn the key back off instead of cranking, then turn the key on and wait for the fuel pump again before cranking. This would cycle the fuel pump 2X.
    Might help, might not - but doesn't cost anything to try. :thumbsup:
  9. Apr 17, 2021 at 9:14 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it does this there is a leak in an injector, check valve or the fuel regulator on the rail.
    6 gearT444E and blu92in99 like this.
  10. Apr 17, 2021 at 4:06 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    From what I've read, the fuel pump only gets power when the engine is running or when tuning it over to start. It doesn't prime the fuel rail first.
  11. Apr 17, 2021 at 5:17 PM
    winkel
    Corydon, IN
    That is my understanding as well.
  12. Apr 17, 2021 at 5:57 PM
    Waasheem
    Waasheem
    2007 xrunner
    I was thinking it might be something to do with oil pressure. It won’t fire the plugs until it has oil pressure, guessing.
    I generally don’t drive it Monday through Friday, mostly only weekends. Mine starts fine in the morning, then say if I make a coffee run, park it and don’t start it until several hours later, it’ll long crank start. But if I run around all day starting and stopping, it starts quickly all day long. Sometimes the first start Saturday morning will long crank start. So I don’t know.
  13. Apr 21, 2021 at 5:09 AM
    Hunter gatherer
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Starts fine now,plugs,air filter,TB MAF cleaned and some injector cleaner in the tank. The plugs weren't bad but as soon as I changed them the truck started easier. Thanks for the replies
    RustyGreen and Toyko Joe like this.
  14. Apr 21, 2021 at 5:15 AM
    Waasheem
    Waasheem
    2007 xrunner
    I’m curious if the gap on the old plugs were large.
  15. Apr 21, 2021 at 5:16 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    :thumbsup:
    Would like to see where you sit after a week. Glad you at least have improved starting now.
  16. Apr 21, 2021 at 5:16 AM
    Hunter gatherer
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    They were pushing about .045
