Particulate Filters Coming. Get Ready
Discussion in '4th Gen. Tacomas (2024+)' started by TacoJonn, Apr 12, 2024.
  1. Apr 12, 2024 at 8:53 AM
    arthur106
    arthur106 Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    This. I'm glad to see Toyota really doubling down on this tech unlike it's peers that are all caught up in the EVs. They should have solid state batter tech on the market in a few years which will be a complete game changer; you'll be able to have 500+ mile range and charge times will come down to reasonable levels. As a gear head, I hate what's become of automobiles; but I've gotta admit that I am a fan of cleaner air.
  2. Apr 12, 2024 at 8:57 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Are we supposed to fear this like our fathers did when EGR and catalytic converters were coming on scene?
  3. Apr 12, 2024 at 12:26 PM
    KevlarBear
    KevlarBear Well-Known Member
    SSM 2023 TRD OR DCSB
    I have nightmares about particulate filters :eek:
    But in all seriousness, whats the big concern with this? Seems like a sensible change to vehicle emissions using known tech (from diesels).
  4. Apr 12, 2024 at 12:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So I guess we will be sitting in the shop parking lot doing this for gas vehicles too now... yea great way to save fuel...not
    TurboDA6 and point45 like this.
  5. Apr 12, 2024 at 12:38 PM
    KevlarBear
    I don't know what your picture is showing. Care to elaborate a bit?
  6. Apr 12, 2024 at 12:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    DPF service (manual) regeneration, basically it runs the engine up to 2000-2500 RPM and dumps raw fuel into the exhaust to heat the DPF up to 1000-1200F to burn the soot to ash. Typically lasts 15-60 minutes on automotive diesels.
    Under normal conditions the vehicle should this on it's own from time to time (typically around every 300-500mi) but many times diesels aren't driven under the right conditions long enough or are idled too much for regenerations to complete on their own.
    Also certain component failures can inhibit regenerations and result in a restricted DPF.
    And finally certain component replacements require that you run a regeneration after.
    KevlarBear[QUOTED] and point45 like this.
  7. Apr 12, 2024 at 12:49 PM
    OpeCity
    Long Beach, CA
    Good news: automotive gas engines generally run hotter EGT so it might not happen as often?
  8. Apr 12, 2024 at 12:54 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Guess we'll see, I haven't seen too many details of how they are going to be implemented on the gasoline side.
    Gasoline engines don't generate much soot at all so I would think the distance between regens should be quite a bit longer.
    I'm more concerned about what it's gona cost to fix this stuff when it breaks, catyletic converters are already stupid money I can't imagine what a cat/GPF assembly would run.
  9. Apr 12, 2024 at 12:58 PM
    KevlarBear
    Thanks for taking the time to explain! I can see how your experience with it could cause some concern.
    Dm93[QUOTED] likes this.
  10. Apr 12, 2024 at 3:05 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's not that I mind messing with them but the amount of steps you have to do in the correct order and the time required for emissions faults on diesels is stupid.
    Like this one, it had a bad reductant (DEF) injector. Takes 10 min to replace but almost 2 hrs to do all the scan tool resets, tests, regen, and test drive to get it out of derate.
