Parting out 2009 Tacoma
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by kriskross, Apr 14, 2014.
  1. May 23, 2014 at 10:12 AM
    #361
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Any of these door panel fasteners available still?
  2. May 25, 2014 at 9:12 AM
    #362
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
    Got my part in ok, fast shipping. Thanks.
  3. May 25, 2014 at 6:35 PM
    #363
    kriskross
    kriskross [OP] Shits & Giggles
    Monterey
    Former 2ndGen Owner, in the market for another
    See Build Thread
    Might be keeping these actually. I'll let you know.
    I'll check
  4. May 27, 2014 at 6:29 AM
    #364
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Photo of the Power Steering hose assembly I asked about.
    Thee are two hoses on the reservoir. One larger than the other. The one I would like is the smaller of the two. In the photos, you can see the large one is on the straight fitting, the smaller hose is on the 45 degree fitting.
    The one on the 45 is the one to focus on, and it is the forward most of the two.
    I have had these off ,y truck before, usually, to remove, use pliers and slide the clamp further onto the hose a couple of inches. Then rather than try to pull the hose off, it seems to work best to push it on slightly first, then twist and remove.
    PK
  5. May 30, 2014 at 1:00 PM
    #365
    taco5221
    taco5221 Member
    11 tacoma
    i want to buy the exaust and headers need your number
  6. May 31, 2014 at 8:05 AM
    #366
    kriskross
    Monterey
    See Build Thread
    PM'd
  7. May 31, 2014 at 8:05 AM
    #367
    kriskross
    Monterey
    See Build Thread
    PMd
  8. May 31, 2014 at 7:24 PM
    #368
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    3rd brake light?
  9. Jun 1, 2014 at 9:22 AM
    #369
    kriskross
    Monterey
    See Build Thread
    The light bulb? Housing? Cover???
  10. Jun 1, 2014 at 9:47 AM
    #370
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    Is the hood release lever assembly available? The one under the dash. Thanks.
  11. Jun 1, 2014 at 10:24 AM
    #371
    kriskross
    Monterey
    See Build Thread
    PM'd
  12. Jun 1, 2014 at 8:47 PM
    #372
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    So here's a weird one.
    Need the U-shaped piece that forms the support posts for the rear of the bed. Called a "Bed Sill" by Toyota. It bolts to the frame, crosses under the bed along the rear edge, the taillights bolt to it. I'm not sure if it's really all that reasonable to ship it, unless you give me an offer I can't refuse.
    Of course, I'm hoping you didn't get hit in the rear or the rear corners......
    Also need one upper bed cubby (above the wheel wells).
    Still haven't heard PM from you about the antenna mount.
  13. Jun 1, 2014 at 9:02 PM
    #373
    DirtJumper14
    SoCal
    2005 TRD OR
    Pm replied and money sent through PayPal. Thank you. Hood release is taken.
  14. Jun 1, 2014 at 9:07 PM
    #374
    kriskross
    Monterey
    See Build Thread
    I think I can pull that frame piece. And I was able to ship my rear bumper for $50 so this shouldn't be too bad either. It is accident free, besides the flooding of course. Can you send a pic of exactly what you want so I know what to remove? PM it.
    I still have one of those bed cubbies left.
    And sorry about the antennae but it had been damaged trying to remove it. I think I was suppose to use some kind of mini spanner wrench but jacked it up trying to use a screw driver and hammer...
  15. Jun 1, 2014 at 9:25 PM
    #375
    Mach375
    Well, to tell you the truth, I'm planning on using it to mount my CB (or Ham, once I get it) antenna on the driver's fender. So if you think it's still useable in that manner, I'd still be interested.
  16. Jun 1, 2014 at 9:27 PM
    #376
    kriskross
    Monterey
    See Build Thread
    Since the fender had already been damaged from a previous offroading trip, I scrapped it. Sorry man.
  17. Jun 1, 2014 at 9:27 PM
    #377
    Mach375
    Long bed? Also need the driver's rear bedside.
    Double-cab? Need the driver's rear door, too.
    Shipping might kill it. Unless you can give The Deal Of The Century...?...
    PM inbound.
  18. Jun 1, 2014 at 9:38 PM
    #378
    soljah111
    soljah111 Well-Known Member
    Jon
    Denver
    11 supah white OR
    None yet
    Do you have the passenger rear window motor? Double cab
  19. Jun 1, 2014 at 9:41 PM
    #379
    kriskross
    Monterey
    See Build Thread
    Do you mean the outside fender piece?
    I have been surprised at how cheap they can ship some of this stuff. The bumper was pretty heavy, 40 lbs, and it was like 5 feet long and still only $50. We can PM more about it though.
    PM'd
  20. Jun 1, 2014 at 9:43 PM
    #380
    kriskross
    Monterey
    See Build Thread
    Nemermind, it's an access cab. My new one is double cab.
