Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. Aug 19, 2015 at 11:36 PM
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Much discussion has been done about what has changed for the 2016, but I thought it might be interesting to talk about what hasn't.
    Looking through the catalog at a few of the things, and as suspected, many parts have carried over into 2016, and not just a seat belt buckle.
    Among things that have remained the same:
    - Clutch pedal and master cylinder
    - Manual transmission case and many non-gear internals (2TR-FE only)
    - Front steering knuckles
    - Front sway bar and end links
    - Upper control arms
    - Front drive shafts (on some models)
    - Front shock mounts
    - Rear leaf spring bushings, shackles, spring mounts and u-bolts
    - Rear shock mounting hardware
    - Front brake rotors, calipers and shims remain the same, however the pad material has changed
    - Rear brakes
    - Brake master cylinder, though the booster has changed
    - Steering components (steering rack, inner and outer tie rods)
    - Air filter and oil filter (2TR-FE only)
    - A number of frame crossmembers (though fewer are sold separately on the 2016 frame)
    - Spare tire carrier
    - Rear floor pan and reinforcements (behind front seats)
    - Non-sliding back glass on 4-cylinder models
    - Door weatherstripping on access-cab
    - Battery carrier/hold-down
    - Fuel tank and "skid plate"
    - Fuel filler neck
    - Throttle pedal
    - Interestingly while the front hubs changed, the bearings themselves remained the same
    - Rear wheel bearings and seals
    - Inside rear view mirror (models without HomeLink or Auto Dimming)
    - Cabin air filter (though a charcoal-type is now listed as being available - 88508-04010)
    - Lug nuts
    - Muffler (2TR-FE only)
    This is by no means a complete or comprehensive list, just some stuff that I had been curious about and so I looked it up.
    Jeff
    ExplorHer, TopherWV, tubesock and 2 others like this.
  2. Aug 20, 2015 at 3:42 AM
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    Once again, beat me to it. I checked before I went to bed and it still wasn't updated. Wanted to see if the bed shell was the same, since people like to argue over things around here
  3. Aug 20, 2015 at 3:44 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    So..... the level lift kits already out should work fine?
  4. Aug 20, 2015 at 4:20 AM
    border411
    border411 Well-Known Member
    Yes
  5. Aug 20, 2015 at 5:01 AM
    BlkTaco47
    BlkTaco47 Unhinged
    Nice. I'm having the tires & wheels that I have now - 285/60/R18 moved to the new
    one when it arrives, they may rub and may not, if they do it'll be great if the current level kits fit.
  6. Aug 20, 2015 at 5:15 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    but will the new oem rim fit the vehicle you have now?
    I am wondering since I have the trd 16" black rims on the 12 Tacoma that I would rather have on the 2016. the new sport comes with P265/65R17.
  7. Aug 20, 2015 at 5:16 AM
    BlkTaco47
    BlkTaco47 Unhinged
    Dealer and their mechanics have already said yes, no issue with the fit on either.
  8. Aug 20, 2015 at 5:23 AM
    NoDak
    JR
    Minot, ND
    well I did a quick compare so it should be almost a perfect swap from the 16 to 17 rims if they fit.
  9. Aug 20, 2015 at 5:25 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Same goddamn lug nuts?!? What kind of ass clownery is this?
    Just kidding - don't care. I just want my truck to show up.
    choupick, Markc1024 and bdunna like this.
  10. Aug 20, 2015 at 5:26 AM
    BlkTaco47
    BlkTaco47 Unhinged
    lol sup man.....I'm sure many will be bitching about that.
  11. Aug 20, 2015 at 6:10 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    You must have forgot about seat belt bracket....
  12. Aug 20, 2015 at 6:15 AM
    BlkTaco47
    BlkTaco47 Unhinged
    and in come the trolls
  13. Aug 20, 2015 at 6:17 AM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Thanks OP.
    Would love to get Toyota's Chief Engineer "Seat Belt" Mike Sweers comment on this. Mr. Sweers went on and on about every part changing except the seat buckle. :facepalm:
    CaptAmerica likes this.
  14. Aug 20, 2015 at 7:00 AM
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    Captain America when is your truck supposed to arrive. Just got my full confirmation of mine yesterday
  15. Aug 20, 2015 at 7:16 AM
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Look up the definition of hyperbole. Folks took his comment literally when it clearly was not.
    Herniator likes this.
  16. Aug 20, 2015 at 7:32 AM
    CaptAmerica
    Cap
    I'm going to over to the dealership at lunchtime. "Someone" stopped answering my emails, and there's a reason I'm infamous around here for getting answers. I'm going in all sunshine and kittens, but my "Marcellus Wallace" will be on deck and raring to go.
  17. Aug 20, 2015 at 8:12 AM
    Tunngavik
    Alberta, Canada
    I know what hyperbole is, but I would expect that from a comedian, a politician or a sleazy salesman - not the Chief Engineer of one of the largest auto manufacturers in the world.
    I work with engineers on a daily basis and they are a dry lot, bound by codes of ethics set by their professional associations that they must belong to in order to practice. Trust me "hyerbole" is not allowed in any professional communication - to client, regulator, whoever.
  18. Aug 20, 2015 at 9:56 AM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    ^ If I accepted your statement as correct, it means Sweers made a mistake. It doesn't make him a liar. Which so many around here seem anxious to do: vilify someone because they can from the shelter of their keyboard.
  19. Aug 20, 2015 at 10:05 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Link to 2016 parts? Curious what limited wheel will cost.
    bdunna likes this.
  20. Aug 20, 2015 at 10:39 AM
    Tunngavik
    Alberta, Canada
    OMG dude. Can you make up anymore excuses. He made this mistake several times....first it was hyperbole, now it's a mistake...what's next, he was drunk those times he said it?
    Do you work for Toyota? It are you a politician?
