Parts extravaganza!!!!
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by tacotunner06, Dec 1, 2021.
  1. Dec 1, 2021 at 9:28 PM
    tacotunner06
    tacotunner06 [OP] Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Most of everything is going to be Local pickup due to the size of everything.
    Factory Seats with Clazzios and front seaters installed. Had these in my truck for 2.5 years. Has seat heaters installed in front seats. Passenger is the fold flat version (can get a picture of the pass seat next week). $400 this includes all seats and covers, save some time and just swap your full seats out and not have to deal with pulling the covers on. Usual wear and tear on passenger side and a very small wear spot by the adjuster levers on the side.
    Viair 2.5 Gallon steel air tank. In good shape with fittings and 150 psi pressure relief. $50
    Threw the Bedsides away so now it is just professionally painted bushwacker flares cut for a Hi Clearance rear bumper $100
    Wilco style tire carrier. Is bolted on one side and pinned on the other and can be installed either with the spare facing in or out. has a fresh coat of Black Steel It on it and will include all new hardware. Designed it to fit a 35" tire. $1200
    Relentless Fabrication Rear Hi Clearance Bumper. Includes squadron pro's. Has been cut for better tire clearance and I added side bars which gives you a standing point if you run a bedrack and gives better protection to the bedside. Also includes a pipe tailgate that i built that holds the spare tire on the outside (up to a 33" tire) and a pelican case on the inside (pelican case also included). tire gate is pinned to a set of total chaos bed stiffners that are also included and has hinges that bolt thru the bumper. sides of the bumper could use touch up of bed liner that i used to closely match the powder coat. Tire gate could use a full recoat or strip and powder coat. $1600
  2. Dec 1, 2021 at 9:57 PM
    VerteX10_
    VerteX10_ Well-Known Member
    Los Angeles, CA
    2010 Magnetic Gray Tacoma
    More to come!!
    I’d be interested in the steering wheel and possibly the headlight supports also if you could ship them :confused:
    Geeves77 likes this.
  3. Dec 2, 2021 at 6:32 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    those I’m sure I can.
  4. Dec 2, 2021 at 6:36 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    GLWS! so much want for the tire gate.....so little funds:annoyed:
    tacotunner06[OP] likes this.
  5. Dec 2, 2021 at 7:47 AM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    how difficult was swapping out the steering wheel?
  6. Dec 2, 2021 at 9:41 AM
    Rainier
    Rainier Well-Known Member
    OC, CA
    Black 15' Tacoma DCSB 6spd
    damn all black dash pieces look good!
  7. Dec 2, 2021 at 9:53 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    not too bad, it’s torque’s to remove the airbag than the main nut and it pops right off.
  8. Dec 2, 2021 at 10:31 AM
    VerteX10_
    Los Angeles, CA
    More to come!!
    Just messaged you!
  9. Dec 2, 2021 at 1:39 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    damn that steering wheel is tempting. was just thinking about this mod the other day. mine is wore out.
  10. Dec 4, 2021 at 8:53 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Just got back from being out of town for work. seems everyone is interested in the wheel...lol will get more pictures of it today and see whos the first to take it i guess.
  11. Dec 4, 2021 at 9:25 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Can you post photos of the tailgate panel?
  12. Dec 4, 2021 at 11:40 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    It is scuffed up from use but no dents.
  13. Dec 4, 2021 at 11:46 AM
    20somethingwidataco
    Will
    Washington State
    Take 50 for it with out the tailgate?
  14. Dec 4, 2021 at 12:01 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    no but you could swap ur plastic on to it and sell it for 50…lmao. Got take the whole thing…lol
  15. Dec 4, 2021 at 4:33 PM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    What did you replace everything with? Stock parts? Or did you go all out on new shit?
  16. Dec 4, 2021 at 5:25 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Prp seats and steering wheel with quick release, advanced fiberglass bedsides and building a new rear bumper and chase rack.
  17. Dec 5, 2021 at 6:20 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I will add to the interest in the steering wheel, controls, spiral cable, and airbag. Not sure if able to ship airbag.
  18. Dec 5, 2021 at 8:55 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Steering wheel is sold.
    Hardscrabble likes this.
  19. Dec 6, 2021 at 6:16 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    How much for the blacked out centre dash piece??
  20. Dec 6, 2021 at 6:53 AM
    brian.gonz
    Brian
    Manor, Texas
    I don't think he's parting out just upgrading
