Parts list for Valve Cover Gasket replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Dec 6, 2017.
  1. Dec 14, 2017 at 8:36 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    While your in there you should grab a feeler gauge and gieck your valve clearences
  2. Dec 14, 2017 at 8:36 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    OP I just suggest giving the dealer parts guy your vin number.
    That should insure correct parts.
  3. Dec 14, 2017 at 8:42 AM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I did already. Everything looks good, but I'm confused about the difference between PN 11188-62010 and 11183-62010. Gunny says he missed that and will add that to my order. I'm guessing one of these are the half moons and the other are the camshaft plugs.
  4. Dec 14, 2017 at 8:42 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I have been told the 3.4L doesn't have as big of a need for valve clearance checks. Is this true?
  5. Dec 14, 2017 at 8:52 AM
    Jcyr
    Jack
    North east
    Neither of them have “huge” needs but it’s pretty dumb to be all the way in there and not check imo
  6. Dec 14, 2017 at 8:54 AM
    Jcyr
    Jack
    North east
    All exhaust valves wear tight over time and itd suck to burn one up only a few k miles after being in there. Easy to check and replace shims
  7. Dec 14, 2017 at 8:56 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I want to say that's a 4 cylinder problem only. I don't believe the 3.4L has this issue... someone correct me if I'm wrong
  8. Dec 14, 2017 at 8:59 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  9. Dec 14, 2017 at 9:00 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  10. Dec 14, 2017 at 9:02 AM
    Jcyr
    Jack
    North east
    Valve clearance
    You are wrong the valve train is similar and from time to time does need to be checked or adjusted it only takes and hour to check your clearances and if you do and ensure your in spec you’ll probably be good for another 100k
  11. Dec 14, 2017 at 9:11 AM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    You don't need the 11183 half moon plugs, they are aluminum and you just clean them up and rvt them back in. Unless u got more money them time and don't want to bother cleaning off the old rvt.
    The 11188 cam seal plug you will need.
    Basically the heads are machined universal to fit both sides so you have to plug up the holes that are not used on the side there on.
  12. Dec 14, 2017 at 9:12 AM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    I would also do spark plugs and wires unless u have done them recently.
  13. Dec 14, 2017 at 9:14 AM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    Not sure why u would need the 90080 bolts ether clean them up and put new washers on.
    Unless they are super rusty or something and u think u may ruin some.
    01x4 likes this.
  14. Dec 14, 2017 at 9:14 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I did them recently, same with PCV valve and grommet. Thanks for the info. I think I am good to confirm with Gunny my order.
    I overtightened mine, and after hearing of people stripping the heads off, I'm going to assume I've weakened mine so I'm gonna just get new ones.
  15. Dec 14, 2017 at 9:16 AM
    #35
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Bolts don't need to be replaced. Order 1 or 2 half moons - they might be brittle - I chipped one, but luckily had a blown engine that I could scavenge one from.
    ThunderOne[OP] likes this.
  16. Dec 14, 2017 at 9:20 AM
    #36
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    sound advice.
  17. Dec 14, 2017 at 9:21 AM
    #37
    Timmah!
    Timmah! Well-Known Member
    TIM
    The camshaft plugs are the full circle plugs on the backs of the heads. You only need 2 of them. The semi-circular plugs are the half moon plugs on the front and rear of each head. You can reuse those semi-circular plugs. You just have to clean them up and then reseal them with FIPG or RTV.
  18. Dec 14, 2017 at 1:18 PM
    #38
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I'm pretty sure my FelPro valve cover came with new valve cover bolts.
    I used the part numbers from the links I posted, and completed my VCG job this past spring. I dunno why those weren't working for you?
    FWIW I replaced my half moons with new ones, they were cheap enough and I didn't want to have to clean the old ones. Call me lazy, but there were only a few bucks.
  19. Dec 14, 2017 at 1:48 PM
    #39
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    almost all part numbers were the same, except for the spark plug tube gaskets, which apparently has been updated to this part number.
    PRODUCT DETAILS PART NUMBER
    11193-70010
    • Manufacturer:Toyota
    • Part Number:11193-70010
    • Part:Valve Cover Gasket
    • Replaces:11193-16010, 11193-0A010
    • Positions:Left, Right
    • Other Names:Gasket, Valve Cover Seal, Valve Cover Tube, Gasket Spark Plug T
    • Description:
      4.7L, spark plug tube. 3.4L, spark plug tube. 2001-04, spark plug tube. 3.5L, without hybrid, spark plug tube.
    • Notes:Included With Valve Cover.
    jjsul[QUOTED] likes this.
  20. Dec 14, 2017 at 1:53 PM
    #40
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    ^^ This ^^
    I have been shopping for Gen 1 Tacos and Gen 2 T4Rs, and that is the best info I have found regarding a very common problem on these engines. The majority of V6's I have looked at on these older trucks have had severe valve cover gasket leaks.
