Parts list for Valve Cover Gasket replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Dec 6, 2017.
  1. Jan 7, 2021 at 7:42 AM
    #61
    DUCKSHOT
    DUCKSHOT Well-Known Member
    TX
    01' Tacoma PreRunner
    Thanks for the info on this!
    Unfortunately right now I'm reading your thread about your S/C....
    I keep going back and forth on rather or now to slap one one with over 200,000 miles on the engine.
    Maybe if I find someone confident in knowing what they're doing here in the Houston area and i decide it's worth it, I'll pull the trigger.
    I'll be driving this as a daily driver for another good year or 2 before I get an F250 but never getting rid of the Taco.
    1997tacomav6[QUOTED] likes this.
  2. Jan 7, 2021 at 7:47 AM
    #62
    1997tacomav6
    Denver
    Your absolutely fine adding a supercharger at 200k
    Just do a compression test 1st and you probably should get the injectors cleaned and serviced and a new fuel pump just because these items are probably not working at 100 percent and New fuel filter
    DUCKSHOT[QUOTED] likes this.
