parts needed for switching from MANUAL HUBS TO AUTO HUBS (ADD)
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4runnercaged, Oct 2, 2013.
  1. Oct 2, 2013 at 11:02 AM
    4runnercaged
    4runnercaged [OP] Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    What all is needed to go from manual hubs to auto hubs?
    spindle, hubs, actuator? (can anyone explain more in detail what needs to be done with the actuator)
    what else would i need?
  2. Oct 2, 2013 at 2:44 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The ADD diff is different than the man hub diff (pass side, side gear and bearing).
    A factory ADD diff can be converted to man hubs with a swap of CVs and spindles and retaining the ADD actuator/tube or swapping over the man hub tube.
    A factory manual hub diff will not accept the ADD intermediate shaft.
    Here
  3. Oct 2, 2013 at 3:07 PM
    4runnercaged
    cody
    arizona
    LOL
    because i have camburg long travel and 4wd.
    what i was origionally told to do was get the tundra axle, swap the tacoma outer CV onto the axle shaft, and out a high angle inner boot on the inner joint.
    well with manual hubs the spline count on the axle is different, on the tundy it is 26 and the tacoma is 34 so i cant possibly put the outer cv joint on to work with the manual hubs. the only way to do this and keeping manual hubs is getting a completely custom axle shaft cut ($$$$$$$$$).
    OR i can swap to ADD and keep the tundra outer cv joint on the shaft and bypass the inssue all together
    FUCK FUCK FUCK.
    thank you for your help
  4. Oct 2, 2013 at 7:07 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    add diff, add cvs, add hubs pressed or replace with add spindles. I was planning to long travel, but would be in your same boat.
  5. Oct 2, 2013 at 7:10 PM
    SafetyDang
    Dang
    Anaheim, CA
    We have a on going thread on ttora. some one said they put the manual ends on to the tundra shafts. Look up trails less traveled I believed he did this but went through to many manual cvs.
  6. Oct 3, 2013 at 8:47 AM
    4runnercaged
    cody
    arizona
    LOL
    ok thx..
    i believe i posted on it.
    yes i was following the trails less traveled guide when i started this and the splines are different. doesnt work
