Passenger dash rattle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DrDuey, Oct 7, 2016.
  1. Feb 17, 2018 at 10:13 AM
    #81
    Tactard45
    Tactard45 Member
    2017 tacoma trd off road
    Skanda seat covers. Memphis speakers
    Just had the dealer fix mine. They added more foam to the panel and the tweeter cover.
    Z_randall likes this.
  2. Mar 16, 2018 at 1:59 PM
    #82
    OH-_SNAP
    OH-_SNAP Well-Known Member
    San Diego, CA
    2016 WHITE LIMITED 4x4 DOUBLE CAB
    ARE V Camper Shell, FiberGlass Hood w/ Functional Skewp. ICON 2.5" Front (ordered)
    Fixed mine, I think, added felt tape to the windshield [passenger side] pillar panel. Added the tap in between the panel and dash - where they meet (or should I say rub).
    rsimi72 likes this.
  3. Jul 12, 2018 at 5:40 PM
    #83
    Z_randall
    Z_randall Spicy Taco
    Zach
    SoCal
    2016 Barcelona Red TRD sporting
    I have the same issue wondering if Toyota will do anything if I take it in
  4. Jul 13, 2018 at 7:56 AM
    #84
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    Just letting all know that since this "fix".. still have never heard the noise again.
  5. Jul 13, 2018 at 8:06 AM
    #85
    Bretsuaz48
    Bretsuaz48 Well-Known Member
    Bret
    Surprise, Arizona
    2016 Sport
    Our 16 did this. I pounded pretty hard on the A piller and it went away. Our 18 has never done this. Overall thought, I am starting to think the 16 was a better truck than the 18 we have.
  6. Jul 13, 2018 at 8:33 AM
    #86
    sendtoharvey
    sendtoharvey Well-Known Member
    Harvey
    SATX
    2018 Sport 4x4 DC
    nothing yet, just tacked on the all weathertech mats and using the free factory cover on the back of it
    when i put the Subaru tweeters in i added a little sound deadening foam to stop the rattle. then two weeks later a lady totalled my truck. my 18 has no rattle...good luck .. my dealer refused my issue 3 times on my 16 fyi
  7. Jul 23, 2018 at 2:12 PM
    #87
    1stGenDriver
    1stGenDriver Now 3rdGenDriver
    Nick
    New Hampshire
    '17 SR5 DCSB 4x4
    It took my 2003 12 years for the passenger side dash area to start creaking and rubbing. Took my 2017 less than 6 months.
  8. Oct 16, 2018 at 9:13 AM
    #88
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I believe this is where my rattle is coming from, any ideas how to fix? I was thinking maybe clear silicone?
  9. Oct 16, 2018 at 8:50 PM
    #89
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    If yours is just the plug and not the real sensor, you can access it easily with the speaker cover removed. You have to pop the A-pillar to do it, but once the cover is off, flip it over and a couple of very small strips of gorilla tape (or any tape really) will secure that plug tightly to the cover. You’ll see when you get under there. Silicone may work too but might be visible if that’s a problem. I just used small strips of tape from underneath.
  10. Oct 17, 2018 at 9:22 AM
    #90
    tacomalimited
    Northern NJ
    No, I have the sensor not just the plug, but the sensor seems to have some play and wiggle a little.
  11. Oct 17, 2018 at 9:25 AM
    #91
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    This is what I had.
    I pulled the cover off. Adjusted the cord going to the light sensor as I thought the might be the cause and then reinstalled. It's gone now .
    I can't confirm which it was as I did both the harness and put it back together in a way it felt tighter.
    rsimi72 and db1984[QUOTED] like this.
  12. Nov 30, 2018 at 3:42 PM
    #92
    Clear7
    Clear7 Well-Known Member
    Ontario
    2017 SR5 2.7L - tried tested & proven
    It just started getting colder, and got the same rattle everyone is talking about. With the defrost blowing heat for a few minutes, the noise settled down. I was convinced it was coming from the overhead console (no sun roof), and that the glue they used up there was getting softened by the heat, making the noise stop.
    I pulled the console down, drove with it out, it still rattled, so knew it wasn't the console itself. Next, the plastic head liner ring wasn't glued securely, also noticed the wires up there looked suspect. I foam taped, wrapped, added padding between everything that touched. Secured everything, total overkill.... and it still made the noise. I even removed the rear view mirror to eliminate it as the cause.
    I finally got someone else driving, while I'm in the passenger side. No question, the noise was coming from the passenger speaker side. I did the sensor button as mentioned, but that wasn't it. Pulled the A pillar off, and speaker out. I applied foam and felt tape to anything that rubbed or touched. Put it back, and sure enough that was it! 100% rattle free now.
    Moral of the story.. even if you're sure it's the overhead console, look at the passenger side!
    For anyone searching in the future, if it is the console, refer to this: https://www.tacomaworld.com/threads/roof-liner-rattle-driving-me-crazy.415868/
    rsimi72 likes this.
  13. Jan 1, 2021 at 3:04 PM
    #93
    Arsenal-16
    Arsenal-16 Well-Known Member
    James
    2020 Silver Tacoma TRD Off Road
    Are you referring to the A-Pillar or the tweeter speaker grill cover?
