Passenger Door Lock goes down
Discussion in '1st Gen. Tacomas (1995-2004)' started by grassroots, Mar 3, 2012.
  1. Mar 3, 2012 at 3:48 PM
    grassroots
    grassroots [OP] Member
    Delaware
    01 PreRunner SR5 Dbl.Cab
    I have a 2001 Tacoma. When I unlock the doors and go to open the passenger front door, the lock goes down halfway and I can't open it. Any ideas? Thanks in advance.
  2. Mar 3, 2012 at 3:54 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Cannot open from inside or outside?-From inside-The wire Actuator may have come off the inside handle. Have you ever had the inside door pannel off? If the door speakers have been replaced-they have been removed. Wires could be getting in the way.
  3. Mar 4, 2012 at 11:14 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    My 99 started doing the same thing, same door. Only happens when I use the outside door handle. My door panels have never been off. I have manual windows and locks so, nothing to do with those wires.
  4. Mar 4, 2012 at 3:23 PM
    grassroots
    Delaware
    It happens from the outside. Don't think the speakers have been replaced.
  5. Mar 6, 2012 at 12:30 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    You will most likely need to pull the door pannel off and look to see what is happening.
    My passenger door -The wire link from the inside handle pops off. Fixed it a couple times-still gets loose every once it a while.--No big deal, since I rarely have passengers.
  6. Mar 6, 2012 at 2:24 PM
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    same exact thing happens with my '99 prerunner when trying to open it from the outside. i've got power locks and all. me and a buddy had taken the door panel off and felt around and realized the rod was bent pretty bad. not sure how to fix or even what parts i would need to replace it and no idea how to even get into the door itself (beyond the panel).
    looking for answers as well :confused:
  7. Mar 6, 2012 at 4:27 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    From another site-found this
    "Maybe the small spring in the lock mechanism, that has broke or come off..
    It wont let You unlock the door unless You pull the spring lever up 1st..
    Go get a good one from a junkyard and replace it, or take the good one out, and You can see how the little spring works."
  8. Mar 6, 2012 at 4:36 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Link for door--has PICTURES
    Good hunting
  9. Mar 6, 2012 at 4:39 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    or this one contains ALL models
