Passenger Door Smart Key System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Apr 22, 2018.
  1. Aug 16, 2018 at 6:44 AM
    #301
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Cool write up! I went up to freeman and got the parts on their way to do this, couldn't help myself.
    Victory[OP] and cemented like this.
  2. Aug 20, 2018 at 2:25 PM
    #302
    Frito
    Frito Well-Known Member
    Wicked Kool !
    Thanks for putting this thread together. Really simple, wonder why I didn't think of this myself ?
    If anyone is contemplating this mod be for-warned that it is a lot more costly than it appears going in given the "mandatory" additional mods that go with it: sound deadening, speaker upgrade and puddle lights:spending: :rolleyes: :cool: :thumbsup:
    Great stuff, I had a blast and really like all these upgrades. Have Fun ! :burnrubber::burnrubber:
    Victory[OP] likes this.
  3. Aug 20, 2018 at 7:20 PM
    #303
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    Puddle lights huh... say more.
  4. Aug 21, 2018 at 1:11 AM
    #304
    Frito
    Check out @Matt Gecko on here. He has a very affordable kit and is a great guy to work with.
    I got a little different setup from SparksParts.com. they also come with footwell lights. They are tied in with the interior light circuit that fades in when you approach the truck with your smart key. Pretty cool and useful effect. Five Stars !
    Check out a thread called " Puddle Lights install & Review" by a member here called "Rising Eagle" :thumbsup: Excellente !
  5. Aug 24, 2018 at 2:22 PM
    #305
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Hey all, it seems like all of the steps to this process have been pretty well documented (with photos and explanations) in this thread. Except for the routing of the wire from the passenger side kick panel to the driver side steering wheel. How did you get the wire under the carpet and through the center console area. Admittedly, I haven't begun the process yet, but I'm the type of guy that likes to study something to death before I attempt a project like this.
    Thanks for the help!
    Toms 17 likes this.
  6. Aug 24, 2018 at 3:15 PM
    #306
    Boricua
    Boricua Well-Known Member
    Jack
    2018 TRD Sport
    Awesome write up, thanks for sharing it with us!!!
    Toms 17 likes this.
  7. Aug 24, 2018 at 4:23 PM
    #307
    Hambone437
    Hambone437 Well-Known Member
    Northern California
    2018 Tacoma TRD Off-road
    Pop & lock power tailgate Passenger Door Smart Key System mod (thank you @Victory) HomeLink garage door rear view Mirror Pro front grille swap Letter inserts on tailgate and glovebox “Tacoma” TSB-0063-18 and TSB-0058-18 performed.
    To get the wire behind the carpet was super easy. The carpet and pad pulls down from the top and is easy to shove the wire behind it and pull the carpet back in place. For me, there was no need to secure the wire to anything. It just sits behind the carpet about 6 to 8 inches below the top. There is no chance for the wire to come out on its own.
    Bertw192[QUOTED] likes this.
  8. Aug 24, 2018 at 4:24 PM
    #308
    Victory
    Victory [OP] Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    The carpet is just laying there, not glued down or anything so just pull it back a little from the very front under the dash and tuck the wire under.
  9. Aug 24, 2018 at 4:27 PM
    #309
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Thanks guys! I'll be tackling this project tomorrow morning. Already have my handle connector wired up. Just need to swap, run and tap everything in the am. Wish me luck!
    1bad2k likes this.
  10. Aug 24, 2018 at 4:36 PM
    #310
    Hambone437
    Northern California
    Good luck. Just follow the directions from Victory (OP) and you will have no problems. The hardest part for me was passing the new wire through the door boot. I used a wire coat hanger and struggled for a while (I was being careful). Try going from the footwell area into the door cavity. I struggled with fishing the wire from the door into the footwell for a long time until I finally tried it in reverse and got it through after only a few seconds. This is a great mod!!
    1bad2k likes this.
  11. Aug 24, 2018 at 6:41 PM
    #311
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Picked my parts up today.
  12. Aug 25, 2018 at 9:52 AM
    #312
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    @Victory @Hambone437
    Mission accomplished! Thanks for the help boys. Awesome write-up. Works perfectly.
    cemented, 1bad2k and Victory[OP] like this.
  13. Aug 25, 2018 at 9:58 AM
    #313
    Hambone437
    Northern California
    Good job! :cheers: Credit is all @Victory , it’s his mod. I just added my experience to it. Glad it worked for you! I remember how excited I was the first time I tried it on the passenger side and it worked. :bananadance:
  14. Aug 25, 2018 at 9:59 AM
    #314
    Frito
    Why did we need 2 different "terminal repair" parts ? Are they the same ?
  15. Aug 25, 2018 at 10:01 AM
    #315
    Hambone437
    Northern California
    Yes, they are the same. But you need two of them.
  16. Aug 25, 2018 at 10:06 AM
    #316
    Victory
    St. Pete, FL
    You can order 2 of the same part, but if you order the two different part numbers the wire colors are different helping you to make sure you wire correctly. The price is the same for both when I ordered.
  17. Aug 25, 2018 at 10:27 AM
    #317
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    FYI, my wire snaking device:
    Bamboo chop stick with a hole drilled in the end. Lace the wire through the hole and then feed it through the door boot, starting on the kick panel side. Worked like a charm, however, it may require an asian wife, who may or may not be angry with me later tonight for cutting it in half and drilling a hole through it. :angrygirl::rolleyes:
    Spadi_5, morcheez26, orion808 and 2 others like this.
  18. Aug 25, 2018 at 10:32 AM
    #318
    Hambone437
    Northern California
    Genius. How long did it take you to fish the wire through?
  19. Aug 25, 2018 at 10:40 AM
    #319
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    O
    Once I used the chopstick... a couple minutes. The failed attempts leading up to that... 20 to 30 min.
  20. Aug 25, 2018 at 11:25 AM
    #320
    Frito
    Thanks for that.... That was the only thing that buzzed me for a bit.
    Those little connectors in the holder were the bugger for me. I almost left out the holder and just slipped on the connectors bare. Thought for a second (only a second :rolleyes:) the different numbers was what was holding me up.
    As an aside, for the guys having difficulty with the corrugated rubber boot in the door.... Pop it out and thread your wires through straight, then reinstall. Easy Peasy that ! :thumbsup:
    This is a wonderfully subtle little mod that is really worthwhile.
    Hambone437[QUOTED] likes this.
