Passenger Door Smart Key System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Apr 22, 2018.
  1. May 1, 2019 at 11:12 PM
    #481
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    Bad connection. Use the volt meter to check if possible.
  2. May 1, 2019 at 11:44 PM
    #482
    Sgrif513
    Sgrif513 Well-Known Member
    2019 Cement TRD Sport DCSB
    Thanks. I'll check it with the voltmeter and see. I appreciate your help.
  3. May 2, 2019 at 2:38 AM
    #483
    seanranger3
    seanranger3 Well-Known Member
    Sean
    Oahu, Hawaii
    2017 TRD Sport 4x4
    I would say you did not set your pins in far enough to the handle
  4. May 2, 2019 at 5:25 AM
    #484
    Victory
    Victory [OP] Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Sean may be on to something here, those pins on your wiring harness you are assembling need to be pushed pretty far into the new connector housing. If you think that is it, use a mini flat head screwdriver to help.
    BountyOR_VF2 likes this.
  5. May 2, 2019 at 6:38 AM
    #485
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    Part number for this OEM harness?
    RushT likes this.
  6. May 2, 2019 at 6:44 AM
    #486
    DSIM
    DSIM Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    FYI to those thinking this could work in the tailgate. Not without a LOT of hacking. I bought a handle to to this mod but also wanted to take it apart and see if it'd be feasible to incorporate the internals in or around the tailgate handle.
    The green wire is the touch sensor, that could probably be switched out for a different touch sensor. The lock touch sensors are the metal flanges near the board. Those could also "maybe" be switched out for a different touch sensor.
    But the board is absolutely BURIED. "Potted" for water resistance. Would be some effort to get it out.
    So I guess the point is it "could" be done but with a ton of effort/hacking. And to destroy a $150 handle just to get to the pieces idk. If someone wants to try then great!
    DSRamsey13 and BountyOR_VF2 like this.
  7. May 2, 2019 at 7:23 AM
    #487
    Sgrif513
    I actually slid the pins directly onto the terminals of the handle, still nothing. I'll try to troubleshoot again.
    Thank you.
  8. May 2, 2019 at 7:31 AM
    #488
    Victory
    St. Pete, FL
    :confused: Must be a bad connection or even a bad handle, you could try swapping handles with the drivers if you can’t find a bad connection.
    Double check that you are tapped into the correct wire locations on the ecu- sometimes colors can change by year, so wire color on my 2016 could (but probably isn’t) different from your 2019, but the wire location should still be the same.
  9. May 2, 2019 at 8:21 AM
    #489
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Lexus SUV’s has a button on the tailgate with a proximity sensor of some sort. Would that be able to connect up to the tailgate to just unlock and lock the tailgate? Of course it would be Lexus parts so it may be a bit pricey.
  10. May 2, 2019 at 8:35 AM
    #490
    caribe makaira
    Caribbean, Puerto Rico
    Show us this LEXUS item...o_O:D
  11. May 2, 2019 at 8:41 AM
    #491
    caribe makaira
    Actually the green wrap wire is an AM antenna...
  12. May 2, 2019 at 8:44 AM
    #492
    TacoTruck808
    I can take a picture of the switch on my wifes NX. Its just a soft touch button covered with rubber on the rear tailgate. I just dont know where the proximity sensor is located. It is probably in the tailgate somewhere. When i have some time, i will see if i can find a parts list or something for her car.
    There is one that locks/unlocks the doors and one that opens/closes the tailgate.
    DSIM likes this.
  13. May 2, 2019 at 8:44 AM
    #493
    DSIM
    Daniel
    Raleigh, NC
    I started trying to research that but I could not find it.
  14. May 2, 2019 at 8:46 AM
    #494
    TacoTruck808
    I will see what i can find on a Lexus parts site.
    DSIM[QUOTED] likes this.
  15. May 2, 2019 at 8:52 AM
    #495
    TacoTruck808
    I found this in the manual but will see if i can find some parts for the system.
    DSIM likes this.
  16. May 2, 2019 at 8:54 AM
    #496
    Sgrif513
    Thanks. The ecu wires are exactly as you described. Hopefully it's not a bad handle. I'm going to remove the passenger side handle and connect it to the ecu outside of the door to see if I can get it to work. If not, I'll swap or for another handle.
  17. May 2, 2019 at 8:54 AM
    #497
    DSIM
    Daniel
    Raleigh, NC
    Question is will the antenna be compatible with the toyota key. (Looking for the same signal as the other antennas). Its rolling code so it needs to be specifically compatible id guess.
  18. May 2, 2019 at 8:56 AM
    #498
    TacoTruck808
    Good question. But if the Lexus Slim card works on the Tacoma, shouldnt it be compatible?
  19. May 2, 2019 at 8:58 AM
    #499
    DSIM
    Daniel
    Raleigh, NC
    Thats the hope.
    TacoTruck808[QUOTED] likes this.
  20. May 2, 2019 at 9:53 AM
    #500
    BountyOR_VF2
    NorCal Bay Area
    Suggestion:
    Why not try to use the new Rav4 rear Foot-Activated Power Liftgate sensor? the one that use your legs to open it? That might be easier to apply on the Tacoma tailgate than retrofit the handle bar.
    https://www.youtube.com/watch?v=YSHhF3uaxgs
    Jessrin, MAS and patdeezy like this.
