Passenger Door Smart Key System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Apr 22, 2018.
  1. Oct 24, 2019 at 3:00 PM
    #601
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Is there any differences if I buy a 2020 passenger handle instead of buying a previous model driver handle?
  2. Oct 24, 2019 at 3:34 PM
    #602
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    That I cannot answer so honestly, I would purchase the one for your year and color. If you looked at mine, you would have no idea that I did it myself (unless you look at where the wires tap into each other), but from the outside of truck it looks factory
  3. Oct 24, 2019 at 4:45 PM
    #603
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    Wouldn’t it be in the part number? If the number is specific to 2016-2019, and there’s a new p/n for the ‘20 (I would say that is doubtful though), then there’s your answer. I would guess it is the same part...
  4. Oct 24, 2019 at 5:20 PM
    #604
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    Wait. The 2020 model does NOT have the keyless entry on the passenger side? So much for progress.
    porterx likes this.
  5. Oct 24, 2019 at 5:21 PM
    #605
    porterx
    porterx Well-Known Member
    Me thinks he is confused.
  6. Oct 24, 2019 at 5:23 PM
    #606
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    The one 2020 that I looked at at my dealer several days ago had the keyless on the passenger side as well as the drivers side.
  7. Oct 24, 2019 at 5:23 PM
    #607
    airmac_11
    Oh- I see. My bad. The 2020 does have keyless on both wings-- okay Toyota about time.
  8. Oct 24, 2019 at 9:25 PM
    #608
    cshrum
    CO Springs, CO
    It’s the same door handle, ladies. There is too much overthinking here. Same truck, only been “refreshed”. Obviously the engineers at Toyota have been logging on to TW
    JenR8r88 likes this.
  9. Oct 28, 2019 at 1:36 AM
    #609
    porterx
    Finally. I bought everything for this mod for myself as a gift last Christmas and just finished installing it. Whoop! Whoop! Praise be to me.
    Now I gotta install the Plug N play harness to relocate USB port. I have it built and modified to fast charge the cell phone and to continously charge the ipod. Just gotta make the time and get motivated.
    cshrum likes this.
  10. Oct 28, 2019 at 5:02 AM
    #610
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Got a link to that? Where are you moving it to?
    porterx[QUOTED] likes this.
  11. Oct 28, 2019 at 5:21 AM
    #611
    porterx
    As was the OPs objective, I'll be running it to the center console so I can keep my ipod there, out of the way. Check out this thread. I'm not the OP but the original thread is somewhat outdated because as was pointed out to me, the original harness didn't take into account USB-C which didn't exist when the thread was started. With a lot of help here, I made a new schematic that will fast charge the newer phones and will keep constant power on the ipod. That schematic is Post #92 on the "Plug N play harness to relocate USB port" thread that I have linked.
    I can't thank the OP of the "Plug N play harness to relocate USB port" thread enough.
    Edit: I just wanted to add a little for those who will but haven't yet completed this mod. Start with 2 conductor sheathed wire. Remove both grommets that are attached to the door and the car. Disconnect both connectors on the car side that the wiring goes to from the door. It just makes it easier to pull the rubber that the wire goes through out into the open space between the car and the door. There is tape around the car end of the rubber but there is a visible slit. This is where you'll want to push your wiring through. If your wire is stout enough, you'll get it through. After that, I connected the wiring to the connector and plugged it into the door handle. Some people let the wire hang low. I put sticky backs along the inside of the door and tie wrapped the wire to them.
  12. Nov 3, 2019 at 6:35 PM
    #612
    MrCball
    MrCball Member
    Utah
    2019 TRD OR DCSB MGM
    Installed the handle and ran the wiring today. Mine is not working, but I think I know why. I bought the repair wires from the eBay link posted earlier and one of the wires won’t go into the housing connector as snug. I tried switching the positaps and triple checked the solder between the repair wires and the wire going to the ECU so I am pretty confident the repair wire connection is the problem. If anyone else has suggestions for where else I may have messed up let me know.
    Don’t know if this would cause an issue as well but the eBay repair wires were smaller than 22 gauge.
    porterx likes this.
  13. Nov 5, 2019 at 10:42 AM
    #613
    MrCball
    MrCball Member
    Utah
    I was able to get the door handle working with the OEM Toyota repair wires.
    The eBay wire connectors were not the same as the OEM ones and wouldn’t seat properly in the housing connector. C0FC7AC8-0AA0-45BB-A6CE-8DB885171599.jpg
  14. Nov 5, 2019 at 11:23 AM
    #614
    tacoWithstickyrice
    tacoWithstickyrice Well-Known Member
    '19 DCSB TRD OffRoad 4x4
    I wonder if it would've seated if you took the seal out?
  15. Nov 5, 2019 at 12:19 PM
    #615
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I used the OEM repair wires and found that I had to rotate them to find the right orientation where they seated into the housing.
  16. Nov 5, 2019 at 1:35 PM
    #616
    MrCball
    MrCball Member
    Utah
    The yellow wires with the seal are the OEM ones that I was able to get into the connector properly. If you look at the connector closely on the green wire it is slightly different than the OEM wire.
    It actually took me a bit with the OEM wires to get them rotated just right to fit properly in the housing connector. I was never able to get the eBay ones to click into the housing
  17. Nov 5, 2019 at 7:21 PM
    #617
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    Has anyone else had luck getting the eBay ones to work?
    I bought them and was planning on doing the install this weekend
    porterx likes this.
  18. Nov 26, 2019 at 1:14 PM
    #618
    roth_nj
    So I installed my handle today and ran the wire to the drivers side while installing my meso puddle lights and door speakers....
    Is it as simple as tapping into pin 3 and 4 in connector c29?
    Right now I have a red wire to the top terminal in the handle and a black one to the bottom... Which ones does to pin 3 and which one to 4?
  19. Nov 26, 2019 at 1:42 PM
    #619
    porterx
    I believe it was opposite. The top wire (your red) goes to the bottom. And the bottom wire (your black) goes to the top. So the red top handle wire goes to pin 4 (green wire) and the black bottom handle wire goes to pin 3 (blue wire).
    I'd suggest using the red posi-taps. It makes a much better connection.
  20. Dec 7, 2019 at 2:21 PM
    #620
    jwilson2899
    jwilson2899 Well-Known Member
    Front Royal, VA
    2017 Tacoma DCSB TRD OR 4x4, BP-51's with medum Dakars, TRD Proser, 285/70/17 KO2s
    Full on TRD "Proseur", BP-51/medium Dakar, 285/70/17 KO2's, HID/LED everywhere
