Passenger Door Smart Key System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Apr 22, 2018.
  1. May 14, 2020 at 7:10 AM
    #721
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    Damn I need to get off my lazy bum and do this mod already
  2. May 14, 2020 at 7:13 AM
    #722
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    Dude... for real. You won't regret it. Have patience with the door boot!
  3. May 14, 2020 at 8:07 AM
    #723
    patdeezy
    souLcaL
    What I should have done was done this mod the same time as the MESO puddle lights :annoyed:
    DSRamsey13[QUOTED] likes this.
  4. May 14, 2020 at 8:16 AM
    #724
    DSRamsey13
    Oh... yeah, man... a third of your work was already done! Now... GET BACK TO IT!
    patdeezy[QUOTED] likes this.
  5. May 14, 2020 at 8:52 AM
    #725
    EagleUSMCRet
    EagleUSMCRet Well-Known Member
    Gettysburg, PA
    2017 MGM 4x4 Tacoma DC Limited
    ESR Qi2 Magnetic Mount MAGSafe charger for iPhone; AVS Vent Visors; Replaced Entune system with Kenwood Excelon Head unit, The Taco Garage DMM for RAM Ball mounts, Blackvue Dash Cam; LED interior light upgrades, ARE Z Cap w/ Yakima Rack, Front Bed Rail, Bed Rug, Tuffy Bed Lock Box, Add a leaf, Pop and Lock, Blendmount and mirror tap for radar detector, AVS Hoodflector, Redline Hood Gas Spring mod. A/C drain mod, X2 Power Premium 27M battery, Debadged the tailgate, Drone Mobile remote start, USB charger for the rear seats, Husky Mats, Victory Lexus Credit Card Transponder Fob, twin Hella Sharptone horns, Bedslide, Gasshole, Meso Fuze cover, TRD Gas cap cover, Passenger side locking door handle, Mr. Produxn license place mount, Total Chaos Bed Stiffeners, Valley Runner Tune, Bed Step....help me I can't stop!!!
    +1 on the boot... the disassembly is rather easy... pick the right wires in the dash... make good connections... and follow the directions @Victory provided. Glad it is standard in the new models. Good luck.
  6. May 14, 2020 at 3:51 PM
    #726
    patdeezy
    souLcaL
    I’m already getting a headache thinking about the fact I have to go thru that boot again
    EagleUSMCRet[QUOTED] likes this.
  7. May 14, 2020 at 5:07 PM
    #727
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    Its not that bad. You can take the boot off and squish it together to make it easier.
    EagleUSMCRet likes this.
  8. May 15, 2020 at 4:58 AM
    #728
    DSRamsey13
    Yeah... what @renlo said. And I recommend you use speaker wires so you just go through the boot once. G'luck!
  9. May 15, 2020 at 5:31 AM
    #729
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Does 22 gauge wires work for this mod and what would be the best taps for it? The only thing I don’t like is that is not a plug and play connection, people have mixed reviews tapping the wires. The good news is that I have talked to @KTJO 4x4 for her feedback and she is considering making a plug and play harness for this mod!:thumbsup:
    stiles88 and patdeezy like this.
  10. May 15, 2020 at 5:40 AM
    #730
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    T-taps are garbage. Use posi-taps.
    STrooper[QUOTED] likes this.
  11. May 15, 2020 at 5:41 AM
    #731
    DSRamsey13
    22 AWG should be good enough. It's not carrying much current.
    To tap the wires, I've been using these for all my mods: https://www.amazon.com/gp/product/B07MLPBPW5/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    patdeezy likes this.
  12. May 15, 2020 at 5:43 AM
    #732
    STrooper
    Jack
    NC
    How does the posi-tabs work??
  13. May 15, 2020 at 5:54 AM
    #733
    DSRamsey13
    "Posi-Tap™ Connectors. Posi-Tap™ Connectors allow you to tap into hot leads without cutting or stripping them. Just insert wire to be tapped into the grey cap and hand tighten into the barrel. The conductor point pierces the tapped stranded wire without compromising its conductive integrity."
  14. May 15, 2020 at 6:34 AM
    #734
    STrooper
    Jack
    NC
    Are the T-taps any good? It seems like you can feed two wires into one, but not sure if they make a good connection once they are pressed inside.
  15. May 15, 2020 at 6:44 AM
    #735
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I've never liked them. They don't always puncture the wire. They don't always stay closed. Posi-taps are easy and reusable. You put the live wire in the top and screw on the middle section. Strip the wire to be tapped, insert into tap and screw the retainer on. Done. Yes they are expensive, but they're very worth it.
    Edit: if there's room, you can tap in multiple wires.
  16. May 15, 2020 at 6:47 AM
    #736
    DSRamsey13
    If used properly, they all should work. Keep in mind, these shouldn't be used where they will be exposed to the elements and will see a lot of "play." It should be... set it... make sure you have connection (test the circuit you just made) and store it away properly... then test it again to make sure you storing it didn't disturb the connection.
  17. May 15, 2020 at 7:38 AM
    #737
    STrooper
    Jack
    NC
    One more question - Do you need to remove the passanger speeker to feed the wires thru the boot?? Thanks for all the help guys!:thumbsup:
    DSRamsey13 likes this.
  18. May 15, 2020 at 7:50 AM
    #738
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    From what I remember. Yes. Wait. I think I did a crappy YouTube video on this. Let me see....
    https://www.youtube.com/watch?v=tjlueaMEKao&t=42s
    Yup. I did.
  19. May 15, 2020 at 7:53 AM
    #739
    DSRamsey13
    I did. Removing and reinstalling the door speaker isn't that hard and having access to that area while you're trying to feed wires through the boot is convenient.
  20. May 15, 2020 at 8:20 AM
    #740
    STrooper
    Jack
    NC
