Passenger door unlock with Smart Key
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ratcityrain, Dec 10, 2016.
  1. Mar 1, 2018 at 12:00 PM
    #101
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Very interested in this, but sadly it seems like a very tall order.
  2. Mar 13, 2018 at 1:55 PM
    #102
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    So unfortunately Ive been super busy lately, gotten into season for me, I probably haven’t been on the forum in over a month and so I haven’t had time to get back into this, but I still think it is possible, probably (hopefully) without too much more work, in fact I still have a (non working) smart handle on my passenger door.
    March and April are going to continue to be busy months for me, hoping someone else gets a chance to get on this, otherwise I’ll be back when I can.
  3. Mar 13, 2018 at 2:02 PM
    #103
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    :pccoffee: :popcorn: I am in no way electrically inclined so i will have to wait until you get around to it.
  4. Mar 13, 2018 at 8:25 PM
    #104
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Thanks for your hard work, even if it doesn't work. I wonder if a Techstream setting...,but probably wishful thinking. Anybody know where that ECU is, next time I am in the dash...
  5. Mar 14, 2018 at 3:16 PM
    #105
    Victory
    St. Pete, FL
    It is just below and to the left of the steering wheel. It has three wiring harnesses going into it.
  6. Mar 14, 2018 at 3:38 PM
    #106
    BigWhiteTRD
    Ted
    Thanks
    Been focusing on the 4wd ECUs on the passenger side (2wd Low and Rear Lock anytime). Let me mention thank you for the work on the Lexus card key, use it and love it.
    You don't happen to have a schematic for that ECU for other vehicle models that have more than 1 door lock/unlock handle? The ECU p/n are the same per my memory from Lexus key discussion, so either the wires that are connected to the ECU let it know to use multiple handles (like 0 specific grounded pin = 1 door control, 1 specific grounded pin = 2 door control.) I hope we might learn of harness differences that way from comparing the two schematics.
    If that isn't it, it would have to be some communication on the CAN I would assume...
  7. Mar 14, 2018 at 3:46 PM
    #107
    Victory
    St. Pete, FL
    I do have the wiring diagram from a highlander, I’ll have to dig it up.
    It still doesn’t work when connected though when you add pins to the connector where the Highlander shows the pinout for the passenger handle even though the pins are in that location in the ecu, so either those pins aren’t connected to the circuit board (I haven’t had a chance to pull the unit and pop it open) or more likely there is a firmware issue.
  8. Mar 14, 2018 at 3:53 PM
    #108
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    Same, our 2012 4Runner has the touch on the passenger door, but not my 2017. It would be nice when loading groceries or kids
  9. Mar 14, 2018 at 3:57 PM
    #109
    BigWhiteTRD
    Ted
    Understood, but if I recall correctly the actual ECU P/N is the same on the highlander as ours, so I have to assume the pins are connected internally to the ECU on our truck. My full thoughts are dependant on that memory, so if it's wrong; ideas -> window
    So that leaves firmware or some other way the ECU can figure out which vehicle it's in. I doubt its the firmware loaded in the box, because 2 different incompatible firmwared boxes wouldn't have same P/N I think?
    One possiblilty
    So it could be the wires connected to the ECU tell it which vehicle. I have experienced on toyota head units, particular grounded wires indicate aux capabilities, etc. these functions are active in other models, so I believe same part can identify the vehicle/functions based on the harness its plugged into.
    Another possibility is the CAN bus data lets the ECU figure it out. And we can't fix that.
    A third possibility is somehow in Techstream. Most likely is that when you reset the ECU (such as wipe all keys) it figures it out from Techstream, and we are not fixing that...
    If we are lucky it might be the first, but hopes aren't up too high....
  10. Mar 14, 2018 at 4:17 PM
    #110
    Victory
    St. Pete, FL
    As far as the part numbers go, I believe I remember the part number on the ecu box itself is the same, but Toyota sells it as an assmbly with the brackets, which of course means the part numbers are different, most likely only because the brackets are different, but maybe there is a chance it could be because the firmware loaded is different as well? Unfortunately programming is outside my expertise, but Ill try.
  11. Mar 14, 2018 at 4:22 PM
    #111
    djmr1972
    djmr1972 Well-Known Member
    N. Central Mass.
    18 Cement TRD Off Road Long Bed
    Visors, Roof rack, decals in and out, bug deflector, tonneau cover, bed extender
    Is there anyway to just connect to the existing wires that go right to the drivers side instead of dealing with ecu or anything related? Wouldnt the passenger side just think it was the drivers side? just curious. hell I want to put lights on my truck and that is way more than I can handle for wiring so I have no idea. I can build a computer from scratch but cant wire a light. go figure.
    tcjacado likes this.
  12. Mar 14, 2018 at 6:25 PM
    #112
    Victory
    St. Pete, FL
    @mesojdm tried that and reported not only did it not work but the driver’s side stopped working as well.
    EDIT: yes thats how we now have it working, should have checked that myself instead of relying on second hand info.
  13. Mar 14, 2018 at 6:30 PM
    #113
    djmr1972
    N. Central Mass.
    oh ok. Im late to the party but was searching for this subject because I was wondering why others have it but my 18 doesnt. thought they added shit not took it away as they progressed. lol
  14. Mar 14, 2018 at 9:30 PM
    #114
    TacoTruck808
    Nope, no one has it as of now, unless someone figured it out and hasnt posted or shared here...:confused:
  15. Apr 21, 2018 at 1:47 PM
    #115
    Victory
    St. Pete, FL
    I have it working in my truck!
    Im having trouble figuring out how to get video posted from my phone on to the site. I have to go to work now and will be gone but ill update this tomorrow.
  16. Apr 21, 2018 at 2:12 PM
    #116
    Victory
    St. Pete, FL
  17. Apr 21, 2018 at 2:28 PM
    #117
    BigWhiteTRD
    Ted
    Going to keep us waiting ehhh?
    Thank you for keeping on this.
    Please hit with handle part numbers when you can (before the rest of the write up if required), so can get these on order..
    9TRDTCO likes this.
  18. Apr 21, 2018 at 3:06 PM
    #118
    Victory
    St. Pete, FL
    Consider the video a teaser, the part numbers as well as the write up will come tomorrow, no one is shipping Saturday night or Sunday anyway. I would post part numbers now but I’m at work and don’t have them with me.
  19. Apr 21, 2018 at 3:22 PM
    #119
    BigWhiteTRD
    Ted
    Thats ok, just giving you a hard time.
    A little suspense in life can be good. Thank you for keeping working on this project.
  20. Apr 21, 2018 at 3:52 PM
    #120
    ratcityrain
    ratcityrain [OP] Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Awesome someone figured it out now I want to do this.
