Passenger floor board leak FIX
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacosConQueso, May 15, 2016.
  1. May 8, 2019 at 4:57 PM
    #61
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    Update: We've had some rain recently including over night and my floor mat is dry! I drank 3 pints of JDM Asahi and celebrated. Just a FYI: taking out the dash to solve this problem is a unnecessary like those before me tried to tell me. Use real seam sealer and don't be afraid to use your hands to spread it while elbow deep...
    CS_AR likes this.
  2. May 8, 2019 at 5:03 PM
    #62
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Good news and CONGRATULATIONS. It's raining right now here. I'm seeing a leak that appears to be down on the door seal. Then right on the lower corner seam, moisture appears but I can't see any source for it. We had a couple of rains and tornados aloft last week. No leaks then.
    rogerman[QUOTED] likes this.
  3. May 8, 2019 at 5:51 PM
    #63
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    My truck was leaking a few years ago on the passenger side, and it was hard to replicate the leak with a hose, but after a good rain I'd come back to wet carpet. It ended up being a leaky windshield channel, but the way I diagnosed it may be helpful to others. I took about 3 or 4 paper towels, placed them at different spots on the inner part of the door and closed the door on them. By seeing which towels got wet I figured out the leak was up high, which ruled out a lot of potential leaky spots.
    CS_AR, cruiserguy and rogerman like this.
  4. May 8, 2019 at 8:30 PM
    #64
    CS_AR
    I think I found another source for the water on the passenger side. There is a rubber seal that runs along the roof and down the A-pillar. There was a buckle in that seal about midway across the top. It has separated from the channel groove where it should be set. I suspect water was getting under the buckled up part and dripping from the top of the door on the area by the kick panel.
  5. May 12, 2019 at 4:21 PM
    #65
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Just found my passenger floor wet after a rain storm:(. Looks like I will be attempting the same thing:annoyed:
    rogerman and CS_AR like this.
  6. May 12, 2019 at 5:46 PM
    #66
    CS_AR
    Here's wishing you the best of luck.
    It has been raining for the past few days. No new water drops on the passenger side. I kept the carpet pulled back so I could monitor it.
    Since then, I've discovered a small leak on the driver side -- far left. I will need to pull the fender and give it the same treatment as the passenger side.
  7. May 12, 2019 at 11:55 PM
    #67
    rogerman
    Roger
    HNL 808, SPN 670
    Good luck. Start early and expect it to take a while.
  8. May 13, 2019 at 9:14 AM
    #68
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    I fortunately don't have this problem but I feel your pain. My Matrix floods the carpet when leaves clog the drains down the fenders.
    Here is some good info on the problem.
  9. May 13, 2019 at 11:05 AM
    #69
    CS_AR
    I wonder how many gold Tacomas have "the leak" compared to other colors?
    GQ7227 likes this.
  10. May 14, 2019 at 12:08 AM
    #70
    airsavage
    Butch
    Mine is gold
  11. May 14, 2019 at 9:31 AM
    #71
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    Looks like its time to do this myself, then rip out the carpet and raptor line the interior.
    My 95 is purple
  12. May 14, 2019 at 4:58 PM
    #72
    rogerman
    Roger
    HNL 808, SPN 670
    If you do, for the sake of those in this thread please document and make a post. I'm tempted to do this to help sound deaden. If money and time were not an issue: https://linex.com/news/2018/10/08/m...tects-against-vehicle-explosive-device-threat Do this to the whole truck inside and out lol.
    GQ7227 likes this.
  13. Jun 5, 2019 at 10:58 PM
    #73
    rogerman
    Roger
    HNL 808, SPN 670
    Just an update: It's been raining a lot lately, sometimes all night long and my carpet has remained dry!
  14. Jun 6, 2019 at 2:53 AM
    #74
    CS_AR
    Great news!
  15. May 20, 2020 at 10:10 AM
    #75
    Isaac850
    Isaac850 Active Member
    Isaac
    1999 Tacoma Prerunner Extended Cab 2.7 liter
    I know this is an old thread but I just did this to my Tacoma and fixed my leak. But when I went to put everything back together I can’t get my windshield wipers to work correctly. When I turn them on they go down first and hit the truck then go up. I’ve tried adjusting them and haven’t been successful. Any idea on how to fix this or did anyone else have an issue similar?
  16. May 20, 2020 at 10:54 AM
    #76
    essbeeach
    essbeeach Well-Known Member
    Winston GA
    2002 5-lug
    Yup, I had the same thing happen. What I did was put the blades on higher than needed then let the wipers run and turned the key off then when they were at the lowest position I switched the key off. Pulled the motor back loose leaving the wipers and linkage at that position. Turned the key back on with motor still disconnected from linkage and allowed it to cycle to normal off position then reconnected it to the linkage and bolted it back up. I thought it would take more than one try to get it perfect but I got it on the first try. Hope it works for you too.
  17. Sep 26, 2022 at 9:47 AM
    #77
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I need to do this. I always get a funky smell whenever it rains or I wash my truck. I'm betting I have the same issue. Did you just spray the flex seal into the seams inside the fender area on the exterior?
    CS_AR[QUOTED] likes this.
  18. Sep 26, 2022 at 10:51 AM
    #78
    CS_AR
    I used a tube on the spray nozzle to direct the flex seal into cracks and crevices around the cowling. It's still holding after all this time.
  19. Sep 27, 2022 at 4:13 PM
    #79
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    so basically you sealed the cowling drainage area from driver side to pass side?
  20. Sep 27, 2022 at 4:35 PM
    #80
    CS_AR
    ThunderOne[QUOTED] likes this.
