Passenger floor Matt wet after long drive with a/c on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jul 16, 2023.
  1. Aug 3, 2023 at 1:37 PM
    #61
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    If this were the problem then your leak would only happen when water was falling on the truck somehow. Most in this thread attributed it to the AC
  2. Aug 3, 2023 at 2:15 PM
    #62
    805 Tacoma Tuning
    805 Tacoma Tuning YotaWerx Authorized Tuner | Ventura County, Ca.
    Tom
    Ventura County
    2020 TRD OFF ROAD DCLB
    Unless the condensate drain line is plugged and backfilling the unit, sealing components will not likely resolve your issue as this does not appear to be an overflow issue.
    Sounds to me like quality insulation needs to be added/implemented around the component which is condensing/dripping. This would effectively eliminate any condensate sweat from dripping onto the floorboard.
    -Tom
    TacoSupremo19 likes this.
  3. Aug 4, 2023 at 11:38 AM
    #63
    big_gas
    big_gas Well-Known Member
    2016 TRD Sport 4x4
    This was from the same A/C drain plug issue! Right under the passenger floor mat.
  4. Nov 25, 2024 at 4:29 PM
    #64
    joeR6
    joeR6 Active Member
    2022 TRD OR M/T
    Reviving this thread. 2022 TRD OR MT. A/C leaks into the passenger footwell on drives over an hour in 90+ heat, which is 7 months out of the year here in central TX. Most noticeable when recirc is off, but it can still leak with recirc on. Started to get that musty smell from the carpet. No bueno. And it sounds like Toyota won't do squat. My last yr of bumper to bumper warranty runs out July 2025 so i'll try and get Toyota to look at it before then. However my dealership is a pain when it comes to any sort of warranty work. Fun times ahead.
    Gfenza89[OP] likes this.
  5. Nov 25, 2024 at 4:40 PM
    #65
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    my POS does this too. I've had some other trucks that would drip a couple of drops but this thing will soak whatever/whomever is underneath it.
    someone said thats why the recirculate is set to come on at start up...thats great except it changes the pitch/pressure of the AC and bugs the F out of me. same for the stupid cheap fan motor sounds like it has leaves in it on lower speeds. jfc i hate this truck.....
