Passenger Mirror help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wilmywood, Jan 5, 2014.
  1. Jan 5, 2014 at 11:08 AM
    Wilmywood
    Wilmywood [OP] New Member
    Max
    Charlotte/Wilmington
    07 PreRunner
    Tinted windows/tail lights, XD series rims
    Recently, a friend of mine snapped the passenger side mirror brackett. The actual mirror itself is intact and does not need replacing. However, the brackett that holds and attatches the mirror to the truck has completely snapped. Any recommendations on how to fix this issue without having to completely replace the entire part (mirror and all) as that is Toyotas only solution.
  2. Jan 5, 2014 at 11:18 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Junk yard or ebay might be your only other solution.
  3. Jan 5, 2014 at 11:42 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  4. Jan 5, 2014 at 12:05 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    thats a great price there. i paid 145 at least a yr ago for one of mine and nope you cant buy seperate parts for em.
  5. Jan 5, 2014 at 5:21 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Can't tell from your pic just what the problem is..... If'n it's just broken plastic... fix it..... Use J B Weld and it will be the strongest piece on your truck....
    Do not replace it if it's just plastic work...too easy to fix man..
    Good luck
  6. Jan 5, 2014 at 5:22 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Duct tape, not masking tape...
    Just messing with you. It's a joke that duct tape fixes everything. :)
  7. Jan 5, 2014 at 5:23 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Other than replacement.
    Head to Lowes and grab either some JB Weld or Plastic Epoxy. Niether will be fun to apply but they will hold. You'd be looking at ~$10 for either product.
