Passenger power window won't work
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreenTacoSr5, Nov 1, 2016.
  1. Nov 24, 2018 at 1:29 AM
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner
    You're lucky, yours is an easy fix....
  2. May 5, 2020 at 9:31 AM
    baachor
    baachor Member
    Nevada City,CA
    2003 4x4 3.4l V6 5spd Extracab
    haha that is crazy! Thank you KdF so much, I fixed mine window thanks to you. Stupid little button!! lol
  3. May 8, 2020 at 7:30 PM
    xtwillie
    xtwillie Well-Known Member
    Kevin
    03 Tacoma
    sounds like a motor. they have temp sensors in them and they go out over time and cause them not to operate or to intermittently operate. I would replace window motor regulator
    Brie likes this.
  4. Jan 19, 2022 at 1:57 PM
    WRDD Taco
    WRDD Taco Big Hobby Guy
    Jake
    Delco, PA
    ‘11 TRD Sport DCLB LT 1G3 Moto Express
    TC Mid Travel +2, TC SUA, king shocks, Swamp Donkey/Rigid lighting, Mechman alt, SOS/Boztek armor, ATH Fab tiedown, full active JL/Audiofrog sound system, NOICO sound deadening EVERYWHERE. Up next: roof/bed rack + dry storage, skids, bumpers, fiberglass, power wire upgrade + frame grounds, LTO battery swap, air compressor, on board pressurized water, powered cooler, suspension seats, frame reinforcement, solid motor/trans mounts.
    Mine was all corroded and went down not up… so I took the door panel off and hit it with some wd40 and had to use a pry bar to get the gear moving again.. works fine now. That’s why I’m guessing some people had to slam their doors.
