Passenger rear sagging problem, help or ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ponokauai, May 2, 2012.
  1. May 2, 2012 at 1:27 AM
    ponokauai
    ponokauai [OP] Member
    pono
    kauai!
    2003 tacoma 4x4 revtek leveling kit 5% tint
    howzit everyone im new to this forum but anyway i have a 2003 tacoma ext. cab 4x4 with a revtek leveling kit w/rear blocks. i got it about 5 months ago from a previous owner but i noticed that the rear passenger side of my bed is sagging. im guessing around 1-2" ive heard of the tacoma lean usually on the other side.
    i bought a set of passenger side set of used leafs off a guy on craigslist from his ext cab tacoma thinking it was maybe my leaf springs that were the reason to the sag but after me and my mechanic friend installed it.. SAME PROBLEM. i am going to go pickup the driver side set of leafs from the same guy i got the passenger set from hoping that maybe my driver side set of leafs was possibly different spring rate from the previous owner??:confused::confused:
    so i am hoping when i go get the driver side leafs from the same tacoma it will level out but if NOT. Anyone got any suggestions or ideas of what it might be from or what i could do to permanently fix this problem or even "bandage" it with possibly some kind of spacer between the frame and bed on my sagging side will that work? any help appreciated!
    btw i am thinking of a front bilstein 5100 adjustable struts with 2.5 or 3" coil spacers in the front and 2.5" - 3" rear lift shackles with either a AAL or blocks. but i wAS also wondering if i will have to tweak any steering or maybe a differential drop kit?? thanks
  2. May 2, 2012 at 2:34 AM
    brianpdx
    brianpdx Well-Known Member
    1999 SR5 TRD 4x4
    Howzit!? I'm on vacation in Maui right now :D I'm always surprised at how many Tacomas run around out here.
    1-2 inches lower on the passenger side rear? Is that correct? Seems unusual. I'm no expert, but I'd bet that replacement leafs (i.e. Wheelers 5 pack) and a new set of Bilstein 5100s (or even heavier duty, depending on how hard you wheel) would even out the rear.
  3. May 2, 2012 at 2:38 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Welcome to TW... heavy weight on passenger side?
    Frank
  4. May 2, 2012 at 5:57 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    hmmmm.......date smaller women? :D JK
    yeah, I would guess a new set of springs would fix it up.
  5. May 2, 2012 at 11:32 AM
    ponokauai
    pono
    kauai!
    aloha brian, i live on kaua'i but yes hawaii is loaded with TOYOTAS on every island haha i guess us hawaiians are smart about what kind of trucks we drive! haha
    anyway yeah its a pretty awkward problem, i started off thinking it was maybe my passenger leafs. i though maybe one of them could have cracked so thats why i replaced that set. i have looked at the leaf set on wheelers but its kinda to pricey for my budget at the moment haha... im hoping the the driver side leaf set from the guy i got the passenger side from will even things out.
    by any chance is there any way my frame could be bent? i am definately hoping not
  6. May 2, 2012 at 11:49 AM
    brianpdx
    1999 SR5 TRD 4x4
  7. May 2, 2012 at 9:50 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Is it possible that the block on one side is smaller than the other?
  8. May 3, 2012 at 11:20 PM
    ponokauai
    pono
    kauai!
    When u look from the rear you can notice that the sagged side of the bed has probably about 1" more space between from the bed to the little lines that run under and across the bottom of the rear windshield
  9. May 3, 2012 at 11:30 PM
    ponokauai
    pono
    kauai!
    Could be possible but I doubt it they look identical but looks can be deceiving
