Passenger Seat belt stuck, might have to replace.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phocas, Jul 13, 2020.
  1. Jul 13, 2020 at 7:06 AM
    phocas
    phocas [OP] Well-Known Member
    Was rewiring speakers and disconnected the seat belt mechanism and when i was trying to put it back it wouldn't retract, so long story short, its stuck stuck. Unable to do much at this point but replace. I didn't see an obvious way to disconnect the yellow wire to the mechanism, does anyone know how to? Looked for videos and posts and nothing specifically. Thanks for any input before I have to drive shamefully to the dealership.
  2. Jul 13, 2020 at 7:10 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I would have thought that the yellow cap attached to the silver cylinder would be a connector of some sort, but failing that, a pair of side cutters will work nicely.
  3. Jul 13, 2020 at 7:11 AM
    phocas
    I will take a closer pic in a few, but didn't look obvious and I didn't want to make things worse.
  4. Jul 13, 2020 at 7:20 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    That's the seat belt pretensioner. It's a small explosive charge that tightens the seat belt in an accident. It should unplug but if you're going to be messing around with it I do it with the battery unplugged as a precaution.
  5. Jul 13, 2020 at 8:59 AM
    phocas
    battery has been unplugged the entire time, here is a better pic, it did look like some sort of device that i should be careful with.
  6. Jul 13, 2020 at 9:00 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This, be careful!
    Unfortunately my mother found out how hard and fast these things retract. She was making a double left with a metro bus that took up both lanes. Her van was totaled, but it was a relatively low speed accident. Her ribs were cracked from the pretensioner on the seatbelt, which then lead to other health problems. They look innocent, but they're not, I'm guessing they're also very expensive to replace.
  7. Jul 13, 2020 at 9:02 AM
    phocas
    looks like 200$ ball park. Finishing up things and then going to connect battery and drive to dealership. Thanks for heads up
  8. Jul 13, 2020 at 9:23 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    That sucks, but I would've guessed more.
    I'm still curious why it won't retract tough. I don't know, but would assume if it was set-off, you would have heard about it, but I don't know boo about it, other than the previous story.
  9. Jul 13, 2020 at 10:04 AM
    phocas
    I think the weights in it perhaps? i had it sideways and just made things worse, now it retracted so much its not moving.
  10. Jul 13, 2020 at 10:06 AM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    I'm not sure how these ones work specifically but I know whenever I had to replace HMMWV seat belts there's a little check ball in there that would only allow the seat belt to move like it should if it was set at the exact correct angle. Might be worth seeing if it's something like that.
    tonered, SR-71A and phocas[OP] like this.
  11. Jul 13, 2020 at 10:07 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Yeah you have to be careful removing seat belts, i make sure to “catch” them with some clips so they can’t retract like that
  12. Jul 14, 2020 at 8:15 AM
    phocas
    Trust me, lesson learned, hopefully someone else sees this and learns. Ill report back when i take it to Toyota and im met with a bill.
    AKGSD[QUOTED] and Chew like this.
  13. Jul 14, 2020 at 8:18 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Unplug it and take it apart. It's "fucked" anyway, might as well learn how it works Jic someone in the future runs into the same issue. My guess is the centrifugal "clutch" (balls) are getting hung up.
    Chew and phocas[OP] like this.
  14. Jul 14, 2020 at 8:20 AM
    phocas
    I did the one side, but not the side with the "charge". I was going to ask a tech at toyota about that and since I am going to pay, i might as well learn something from it.
  15. Jul 14, 2020 at 8:32 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Could you not put it back together, take it to the dealer, plead ignorance and try and get it warrantied?
    Just thinkin out loud.......
  16. Jul 14, 2020 at 8:43 AM
    phocas
    The side that doesnt have the charge is easy to take off and put back on, which i did put back together. I am going to go to the dealership and tell them i tried to fix it myself and obviously something is not working right. I will be honest and let the cards fall where they may. Just super annoying.
  17. Jul 14, 2020 at 9:37 AM
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    i agree with tall dave. put back together and go to dealer and say my seatbelt screwed up, i dont know what happened.
  18. Jul 14, 2020 at 9:38 AM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    and do not take apart
    phocas[OP] likes this.
  19. Jul 14, 2020 at 10:38 AM
    AKGSD
    Joe
    Alaska
    Hm. My friends dog used to chew his seatbelts, he found a place that would fix them for $75 online. Maybe you could try a place like that? Surely cheaper than the dealer
    Canufixit and phocas[OP] like this.
  20. Jun 24, 2023 at 5:55 AM
    PascoTaco69
    PascoTaco69 Member
    Adrian
    Brooksville, FL
    2023 Blue Crush Metallic OR MT
    What was the fix for this? Any luck?
