Passenger seat shaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yams, Oct 2, 2022.
  1. Oct 2, 2022 at 1:38 PM
    Yams
    Yams [OP] Well-Known Member
    2020 Black Tacoma SR5
    My passenger seat likes to shake like no other. It's beyond annoying. Higher the speed the more it likes to shake. Is something loose?
    burnttaco7 likes this.
  2. Oct 2, 2022 at 1:40 PM
    Bishop84
    Bishop84 Well-Known Member
    Fairly normal, but I usually get them to shake less after a tire rebalance.
    if it’s a long drive and annoying try to buckle the seat belt on it and put the shoulder strap behind the seat back.
  3. Oct 2, 2022 at 1:42 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Could be out of balance wheels.
    One on of my previous vehicles had horrible seat shake at freeway speeds and it turned out one of my rear tires was out of balance.
  4. Oct 2, 2022 at 1:52 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There are bolts that hold the front passenger seat. Give them a uggaduga.
    AmateurTaco1313 likes this.
  5. Oct 2, 2022 at 1:57 PM
    Trail Limo
    Trail Limo Well-Known Member
    It's slop in the rails that the seat rides on. You could try sliding the seat forward or back to see if it gets better.
    Unfortunately it's normal for these seats... Whatever you do don't have the dealer try to fix it... I made that mistake and very much regret it.
  6. Oct 2, 2022 at 1:59 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If the seat shakes, it's in the rear tires.
    If the steering wheel shakes, it's in the front tires.
    Late Camaro likes this.
  7. Oct 2, 2022 at 3:17 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Yes try moving the seat yourself. As other said, check bolts then the rails. You should be able to figure this out without ever leaving the driveway.
  8. Oct 2, 2022 at 3:22 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    I keep a rag shoved between the console and the seat to stop the shake. It falls out if some runs the seat forward and back a few times, but I just shove it back in.
  9. Oct 2, 2022 at 3:24 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Can you move seat back some or move whole seat forwad or back and make sure its locked good?
