Passenger Seat Very Wobbly Loud Noise.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nwp31, Oct 1, 2019.
  1. Oct 1, 2019 at 7:47 PM
    nwp31
    nwp31 [OP] Member
    Nathan
    Utah
    2012 Tacoma TRD Off Road Extra Cab 4.0L V6 Manuel 6 speed
    None yet.
    2012 Access Cab
    The passenger seat shakes and makes a loud noise every time I hit a large bump or pot hole. Being that I bought this truck for off roading I expect things to rattle and shake, but this is just obnoxious. I originally thought it was the doors but after tightening those up the sound is still present. I do believe it’s either in the slide rails or the connection between the back rest and the actual seat.
    I have already tightened the 4 bolts that hold the entire seat down, at that point I took the entire seat out and tried to find the issue, unsuccessfully.
    My questions are:
    Does/has anyone have/had a similar issue?
    How do I tighten the two parts of the seat?
    If it is the slide rails, how would I fix them or where would be the best place to find a replacement?
    I realize these are kind of weird question, but I would greatly appreciate any feedback!
    RobP62 likes this.
  2. Oct 1, 2019 at 7:52 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    There are two slide bolts under the front of the seat. Just scoot your seat back and you can see them. The other two are behind the seat. You have to pop of a small plastic piece above the rail on each side. Not my photos
    nwp31[OP] likes this.
  3. Oct 1, 2019 at 7:53 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Definitely search on here, I've seen posts where they tighten something in the recline mechanism maybe that eliminates it.
    nwp31[QUOTED][OP] likes this.
  4. Oct 1, 2019 at 8:02 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Also, the headrests can make some serious noise. Take it out and jostle (yea, I said jostle o_O ) the seat and see if it still does it.
    nwp31[OP] and Thuguon2.7 like this.
  5. Oct 1, 2019 at 8:05 PM
    nwp31
    nwp31 [OP] Member
    Nathan
    Utah
    None yet.
    Yea I did try removing the head rest that didn’t seem to be it. It does make a noise but not the one I’m currently tracking down.
  6. Oct 1, 2019 at 8:16 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ok
  7. Oct 1, 2019 at 9:13 PM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    On my 12 the passenger seat bounces around a lot and is noisy. From what I’ve read there is not a solution yet. Keep us posted PLEASE
  8. Oct 1, 2019 at 9:26 PM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Interesting that others are having this same problem.
    My X-Runner does this, always has.
    I just assumed it was due to the previous owner having a heavy passenger or the seat having been in/out a couple of times. Bought the truck used so...
  9. Oct 1, 2019 at 9:29 PM
    nwp31
    nwp31 [OP] Member
    Nathan
    Utah
    None yet.
    I’m gonna be focusing on getting this fixed over the next few weeks on my days off. I’ll let y’all know if I figure it out.
  10. Oct 1, 2019 at 9:52 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  11. Oct 1, 2019 at 10:25 PM
    nwp31
    nwp31 [OP] Member
    Nathan
    Utah
    None yet.
    Thanks for sending that thread fro custom tacos. I think this may very well be it. I’m gonna go try this rn.
  12. Oct 1, 2019 at 10:38 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    I use my passenger seat as a paint shaker. I pick up my rattle cans or gallon paint cans and by the time I'm home they're ready to use :thumbsup:
  13. Oct 1, 2019 at 10:44 PM
    hoverlover
    Mostly Zip-Ties
    But seriously. It is annoying how much the seat shakes. Tightening the bolts did nothing. Luckily I'm mostly deaf and if it's making any noise I can't hear it over the tires/radio
  14. Oct 1, 2019 at 10:46 PM
    nwp31
    nwp31 [OP] Member
    Nathan
    Utah
    None yet.
    While the customtacos.com solution is accurate, that mechanism is very loose. It appears to be something else.
  15. Oct 1, 2019 at 11:23 PM
    redzmvt
    redzmvt Well-Known Member
    Scott
    Western Wisc.
    2011 Regular Cab 4x4 Auto stock
    Bone stock for now
    Mine does the same.I just reclined the seat and fastened the seat belt.It helped somewhat.
