Passenger seat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mark2021, Feb 19, 2022.
  1. Feb 19, 2022 at 5:57 AM
    Mark2021
    Mark2021 [OP] Member
    2021 Tacoma TRD sport
    my passenger seat sounds like its loose and rattles loud when going over big bumps. Anyone else have this and if so is there any way to quiet it down?
    Lenny Dykstradamus likes this.
  2. Feb 19, 2022 at 5:59 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    See if the bolts holding the seat in place are tight.
  3. Feb 19, 2022 at 6:01 AM
    JustJon
    JustJon Well-Known Member
    MI
    18 DCSB OR
    Might be the seatbelt rattling against the b post too.
    OldGuyLikesTacos, Kyebasse and Mark77 like this.
  4. Feb 19, 2022 at 6:43 AM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    Might be looseness in the track. Try checking the adjustment bar to make sure it is fully seated in the position grooves. I’ve heard this before in my truck and that may have helped. I’m still checking it out. Might also be the seat back. Interested if you figure it out 100%.
  5. Feb 19, 2022 at 6:54 AM
    Lenny Dykstradamus
    Lenny Dykstradamus Well-Known Member
    Lenny
    New York City
    Tacoma Warthog
    Mine does it too drives me crazy when i pay attention to it
    its not the track or bolts, its like the whole seat assembly has a bit of play in it (and no one really ever sits in it)
  6. Feb 19, 2022 at 6:57 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Mine did it for quite a while when the truck was brand new and it drove me nuts trying to track down the rattle. It wound up being that the upper part of the seat would shake and rattle the center console cover. I stuck something between them to act as a buffer and that stopped it. After a while I took the buffer out and the rattle didn't return
  7. Feb 19, 2022 at 6:58 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Depending on the road my passenger seat does this too
    If you recline the seat back a smidge and change the angle it helps a great deal with my truck
  8. Feb 19, 2022 at 7:14 AM
    JakNY
    JakNY 30yr/360,000mi Plan
    Jack
    NNY
    21 TRD PRO DCSB SUPER WHITE
    I've found inviting wife turns rattle to whine.
    Bronxguy, Gamma11, Malvolio and 4 others like this.
  9. Feb 19, 2022 at 7:53 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Both my seats rattle unless someone is sitting on them.
  10. Feb 19, 2022 at 10:24 AM
    papito3kids
    papito3kids Well-Known Member
    Patrick
    Colorado Springs
    2020 TRD Sport AC/6MT Cement, 23 4Runner Limited Classic Silver
    Move the seat one notch forward from the rear-most setting. Mine had the same issue and that solved it. Cheap to at least try.
  11. Feb 19, 2022 at 10:26 AM
    Duckinatruck
    Duckinatruck Well-Known Member
    2019 OR DCLB
    How would you know about the driver seat? I’m truly perplexed.
  12. Feb 19, 2022 at 2:31 PM
    Tacomike18
    J
    The truck is parked in the driveway and I move each seat one at a time and both have a little wiggle to them.
  13. Feb 19, 2022 at 2:43 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    JustJon, Malvolio and MaxGeog like this.
