passenger seatbelt light?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDfarmerTN, May 19, 2009.
  1. May 19, 2009 at 3:38 PM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    is there any way to turn off the passenger seatbelt light that flashes on the dash if they dont have the seatbelt on??? i thought about lookin under the seat if theres a plug and unplug it...
  2. May 19, 2009 at 3:39 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    why would you do that! click it or ticket!... jk.. i have no idea..
  3. May 19, 2009 at 4:54 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Pull the light out? Look into the removal of the radio bezel, climate controls come out easily with a flat head wrapped in tape, radio bezel comes off with 4 10mm bolts, you'll see the box.
    Or, i'm sure you could cut the ground wire to it... I'll look it up, give me a couple mins.
    Keep in mind, I think theres two sensors in the seat.
    EDIT: Theres only one sensor, the other is the seat belt sensor. DO NOT DISCONNECT the sensors. They're tied in with the airbags in the schematic. Since schematics do not break down each wire, I cannot guarantee that the airbag will deploy. Pull the radio bezel, and look into the back of the light. I feel that as long as there is more than two wires coming out of that light assembly, you should be ok by simply pulling the light bulb. That would be my suggested route. Lightbulb out, problem solved, while everything should still work fine.
  4. May 20, 2009 at 5:50 AM
    TRDfarmerTN
    thanks for all the info man!!! ill give that a try
  5. May 20, 2009 at 7:04 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    My solution is slam on the brakes and have the passenger fly into the dash/windshield. Doesn't work as well on the tacoma as it did in my g35 and 3000gt, but it got the point across and they belted up.
  6. May 20, 2009 at 7:42 AM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Not to be a dick or anything but,why dont you just buckle up? It takes no time and saves lives.
  7. May 20, 2009 at 8:28 AM
    wcm608
    wcm608 Well-Known Member
    Pittsburgh, Pa
    08 DC LB 4x4 SR5 Impulse Red
    Don't use a screwdriver on the ac bezel. Pull the left and right knobs off and
    use something with a hook and pull. You'll be pulling at the area of where the
    removed knobs.
  8. May 20, 2009 at 8:33 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    If you use the code to turn off the beeping reminder sound does it also turn off the flashing light reminder?
    I havent turned off my passenger side but I have disabled that annoying beeping sound from when the seat belt isnt fastened on the drivers side
    i read this on here somewhere.
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    this works for the driver's side. for the passenger do the same but have sit in the passenger seat
    05Taco4x4 likes this.
  9. May 20, 2009 at 11:14 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    get in there and put some electrical tape over the LED that lights the seat belt light.. DONE.
    But.. yah, just buckle up.
  10. May 20, 2009 at 12:46 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    x15 on buckling up. I require it because it's a law in PA punishable by fine. I would not allow someone to force me to speed and I will not allow someone to risk getting me a seatbelt ticket.
    They can live as dangerously as they wish...so long as it does not cost me $$$.
  11. May 20, 2009 at 2:58 PM
    brian
    Elizabeth City, NC
    C'mon guys, he's not talking about NOT BUCKLING UP. Quit giving him shit for it. He's annoyed by the light flashing when he puts something with any weight in the passengers seat. We all know that sensor is very sensitive, the slightest thing sets it off.
    wcm608, I'm sure that works, but theres nothing wrong with the screwdriver method if you use a very small one thats taped. This is the way its prescribed in the service manual. I've pulled mine out over half a dozen times so far and I have absolutely no marks on it.
  12. May 20, 2009 at 3:49 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Depends where you live, in Alberta (not sure about the rest of Canada) if the passenger is over 18 and not buckled up, they get the ticket. If they are under 18, the driver gets the ticket.
  13. May 20, 2009 at 3:51 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    you could just unplug the plug under the seat and ground it out..
  14. May 20, 2009 at 4:41 PM
    brian
    Elizabeth City, NC
    Have you actually tried this? I'm looking at the schematic, and IF it follows the rules of schematics, then if you ground it out the light will ALWAYS be on. The sensor is a normally closed switch, it opens when you sit in it.
  15. May 20, 2009 at 4:44 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    One way to find out! ground it out using a jumper wire on the negative side terminal and if it still blinks, then make a wire into a loop and hook that wire from one terminal to the other. One of those two ways will stop the blink, and neither will harm anything.
  16. May 20, 2009 at 4:50 PM
    GSB
    GSB Well-Known Member
    Odenton, MD 21113
    09 TRD Sport DC Long Bed
    You could try to go to a junk yard and get a seatbelt buckle out of a wreck. Just click it in and the light and alarm should go out. I have heard people who have dogs that sit in the front seat doing this.
  17. May 20, 2009 at 4:51 PM
    TRDfarmerTN
  18. May 20, 2009 at 4:51 PM
    brian
    Elizabeth City, NC
    Meh, as an electronics tech, since I don't have a wiring diagram, and only a schematic, I can't really go with ya saying "it wont harm anything". Its on the same circuit as the airbags powerwise.... while its not on the same string, I can't verify how it will affect the airbags deployment. Sure it looks okay, but I wouldn't recommend it.
    I still think, while not as 'simple', pulling out the lightbulb is the safest most logical way to do this.
  19. May 20, 2009 at 4:54 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    eh, works for me. I dont think the air bag would be connected to if the passenger has a seatbelt on or not.. BUT better safe than sorry
  20. May 20, 2009 at 4:58 PM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Umm don't you have a key lock on your dash that can turn the airbag off?
    Maybe it turns the seatbelt light off too. Just a thought, especially if the sensors are run with the airbag.
    I don't even worry about it though, at least it's not like the prius/corolla and beeps for 30 seconds
