Passenger Side Bed Panel Damage- any ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wgb89, Mar 21, 2015.
  1. Mar 21, 2015 at 10:58 AM
    wgb89
    wgb89 [OP] Well-Known Member
    North Carolina
    05 Prerunner SR5 DCLB
    Bilstien 5100s Added Leaf 17x9 Wheels 285 BF Goodrich KO Aftermarket 2 sets of Boston Component Speakers Sony Head unit 2 2way pioneer amplifiers to power component speakers Reese Hitch Tinted windows
    About a year ago I was it an accident due to ice on the roads. The wreck was not my fault there for I collected money. On the bright side of things, this game me the cash I needed to replace the shocks, add a leaf, and purchase new wheels and tires, however I yet to fix the bed. I initially took the panel off and banged out the large dent and bolted it back on and I was fine with that. However as of late Ive grown tired of the way it looks and am ready to fix the issue. Affordability is key in deciding on how to fix the problem. I can order a new primed bed panel through the dealership and put it on for $500. Would it be possible to fix for cheaper, hypothetically I would like to have the entire truck painted so it will match. Any idea on how to keep this under $1000. thanks
  2. Mar 21, 2015 at 11:03 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No way you'll get a replacement bedside and full paint job for $1k unless you're doing everything yourself paint-wise. I'd leave it as is until the cash is available (since you had the cash and spent it on other things) and then do it. Rolling with a primer'd bedside will probably be less enjoyable than a dented one.
  3. Mar 21, 2015 at 11:09 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    @wgb89: what color is your truck? If it's a simple color like white or dark blue, you can probably get the bedside painted and the door blended for $500. A more complicated color like black sand pearl (black with tiny brown specks in it) would probably cost more and be harder to match.
  4. Mar 21, 2015 at 11:11 AM
    wgb89
    North Carolina
    thanks for your input
  5. Mar 21, 2015 at 11:11 AM
    wgb89
    North Carolina
    I do believe i have the black sandpearl
  6. Mar 21, 2015 at 11:17 AM
    KenLyns
    Belly of the Beast
    ^Yep. Just saw the pics you uploaded in your gallery. The "black" in '05-'10 was black sand pearl. In this case, painting a bedside and blending one rear door will probably cost more than $500.
  7. Mar 21, 2015 at 11:29 AM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    Perfect opportunity for fiberglass baja bedsides, and of course fenders
  8. Mar 21, 2015 at 11:36 AM
    wgb89
    North Carolina
    how much do those run won't it look silly on my 285 tires
  9. Mar 21, 2015 at 11:43 AM
    scottfarm
    scottfarm Well-Known Member
    Florida
    tacoma 4X4
    aires 3D mats, scan gauge II, rear differential breather relocation, and bakflip G2 bed cover.
    Get the body panel for $500 then vinyl wrap it for another $500
  10. Mar 21, 2015 at 11:44 AM
    KenLyns
    Belly of the Beast
  11. Mar 21, 2015 at 11:46 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
  12. Mar 21, 2015 at 11:48 AM
    KenLyns
    Belly of the Beast
    Based on the Colorado chassis-cab's EPA rating, expect a 2-mpg hit with the flatbed on the highway. :D
  13. Mar 21, 2015 at 11:49 AM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    This!
  14. Mar 21, 2015 at 11:52 AM
    wgb89
    North Carolina
    Ive thought flatbed as well but this is my everyday drive. Same deal with custom body panels, Im thinking something that is not so aggressive. Im going after a tastefull slightly modified look without spending a lot. Its an 05 and ill be driving it for a while so it would be nice to find a modern looking solution that still blends in with the cab and the rest of the truck.
  15. Mar 21, 2015 at 12:02 PM
    Idaholandho
    Ah. Although, flatbedding a truck is very forward thinking on trucks and becoming more popular every day no matter if it is a daily driver or not. Many find that it it provides far more function than a tubbed bed.
    Anyway, the best of luck!
  16. Mar 21, 2015 at 12:06 PM
    wgb89
    North Carolina
    ill look into that thanks
