passenger side clunk/pop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UncleHack91, Mar 30, 2023.
  1. Mar 30, 2023 at 4:08 PM
    UncleHack91
    UncleHack91 [OP] Member
    2014 double cab 6 speed TRD sport
    hey guys has anyone had or have a clunk or pop coming from the passenger side front area? In the morning when I first start the vehicle, let her warm up for a bit then as I start to take off it is a very noticeable (clunk/pop) under the passenger floor board/dash area. I have replaced upper and lower ball joints on both sides, tie rods, sway bar links with Moog and it is still continuing. wondering if front Dif or steering rack bushings could cause this or something else. any info would be greatly appreciated.
  2. Mar 30, 2023 at 5:16 PM
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black Tx Baja
    I have the same issue. Going with CV Axel. Replacing both sides next week and I’ll let ya know how it turns out.
    Happens when I go from stand still to reverse and sometimes when turning in/out of a parking spot.
  3. Mar 30, 2023 at 6:25 PM
    UncleHack91
    Yeah let me know. Maybe I over looked something when I had mine apart.
  4. Mar 30, 2023 at 6:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When mine “clunked”, it was the lower control arm bolt.
    Since you say you replaced the LBJ, check the LCA bolts.
    winkel likes this.
  5. Mar 30, 2023 at 7:05 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Yes but I had a blown shock and the sway bar links were worn. But it sounds like you already replaced those. Links anyway. Hopefully you can track it down. Best of luck
  6. Mar 30, 2023 at 10:35 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Wouldn’t it be nice if, for once, the LCA bolts were loose, instead of completely frozen? :rolleyes:
    TnShooter[QUOTED] likes this.
  7. Mar 31, 2023 at 9:20 AM
    UncleHack91
    Haha yea if only things could be easy. Well I’m going to get it on the lift this weekend and checked on parts through Toyota and seeing they want you arm and leg for one bushing is there an alternative brand?
  8. Mar 31, 2023 at 11:40 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Time to stop throwing parts at it and do some solid diagnostic work for several reasons. First, unless you're replacing the old parts with new OEM parts, you run a pretty decent risk of installing stuff that won't last nearly as long as the originals. Second, it's (still) costing you money and you still have the original problem. Third, unless you have over 150,000 miles on it, you probably replaced parts that didn't need to be replaced.
    So, how many miles are on the truck?
  9. Mar 31, 2023 at 12:33 PM
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    Check the hood. Push down on it. Mine was clunking. There's an adjustable rubber plug on either side of the radiator. Also your core mount bushings may be worn out causing clunks.
  10. Mar 31, 2023 at 4:39 PM
    UncleHack91
    Well I’m not throwing parts at a problem that’s why I am asking about a situation there is 121k on it,
  11. Mar 31, 2023 at 6:02 PM
    zippo88
    L
    2012 sport
    You can check the core support bushing pretty easily too. Search the forums on replacement and you can see what it takes to pull them/check for wear.. pushing on the hood is free, too.
  12. Mar 31, 2023 at 6:08 PM
    zippo88
    L
    2012 sport
    My guess is its that or your cab mounts.
