Passenger side half shaft broke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoffengineering, May 22, 2021.
  1. May 22, 2021 at 1:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Thanks man:thumbsup:
    EatSleepTacos[QUOTED] likes this.
  2. May 22, 2021 at 1:25 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I think this method should work, assuming OP can wiggle the shaft portion out of there. I think it literally slides out of both cups if you can get the boot cut or separated. The two cups will remain in place for OP to limp home in 2wd. At least in theory.
  3. May 22, 2021 at 1:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If only it were that easy. The outer joint, on the wheel side, is a damn bear to separate. Even at home with proper tools I couldn’t do it without cutting the axle to pieces.
    TnShooter likes this.
  4. May 22, 2021 at 1:26 PM
    azzwethinkweiz
    Tucson, AZ
    Oh bummer :(
    I've only rebuilt the inboard portion of the halfshafts.
  5. May 22, 2021 at 1:38 PM
    azzwethinkweiz
    Tucson, AZ
    I like the idea of cutting the shaft with a grinder just to get home, then you can do a proper axle replacement easier at home rather then out on the trail. Bedside power and harbor freight grinder ftw.
    whatstcp[QUOTED] likes this.
  6. May 22, 2021 at 1:41 PM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Just don’t start a fire cutting shit on the trail
  7. May 22, 2021 at 1:42 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Cutting through an inch of hardened steel with not much room to work and fragile components nearby sounds much worse than a trail CV swap.
  8. May 22, 2021 at 1:43 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah I wouldn’t cut it on the truck.
    All this is likely a moot point though. If OP carries a trail angle grinder, he’d probably be carrying a spare CV as well.
  9. May 22, 2021 at 1:59 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'd highly advise Not use a grinder anywhere along the Cajon pass as the brush is highly combustible there . There's been many brush fires there in the last month
    I wish I could help you as I'm probably the closest to your location as I'm up the hill from you in Hesperia but I can't due to health & disability reasons
    My suggestion is if it's movable to have another truck tow you down to the trailhead on Kenwood / I -15 then have a tow truck get you home
    whatstcp likes this.
  10. May 22, 2021 at 2:10 PM
    hoffengineering
    hoffengineering [OP] Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Alright guys, managed to jack the truck up, slide the half shaft back into the inboard CV cup, going to try to limp it back home.
    Thanks for the input everyone. I'll keep everyone posted to make sure I get back the the highway
  11. May 22, 2021 at 2:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you can, minimize 4wd usage as you limp away. It’ll minimize stress on it since it’s just spinning, no actual load on it.
    Taco-Obsessed, TnShooter and tcjacado like this.
  12. May 22, 2021 at 2:15 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Yeah, will do. The bearings on the half shaft are toast, so going to be taking it really easy.
  13. May 22, 2021 at 2:26 PM
    tcjacado
    tcjacado Well-Known Member
    He doesn't need 4wd for the fire road side. All 2wd friendly.
  14. May 22, 2021 at 2:46 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    I was thinking the same thing. He either has a internal shock failure it he is running a spacer on top of his OME shocks. Either way that should never happen if neither of those 2 things are present.
    whatstcp[QUOTED] and tcjacado like this.
  15. May 22, 2021 at 3:03 PM
    #35
    eon_blue
    Azusa, CA
    This is what I would recommend doing. I always bring a spare cv and tools to swap on any trail in case this happens.
    Or if you have a cutting tool maybe you could cut the shaft off the axle. Keep both ends attached at the diff and at the wheel though. The axle nut on the wheel side keeps your wheel bearing together, can't run without that. The other end will keep your diff from losing its gear oil
    That way though you could drive out in 2wd.
    If you have the tools and a new axle however I think a trail swap would be more ideal
    Hobbs and tcjacado like this.
  16. May 22, 2021 at 3:04 PM
    #36
    tcjacado
    He put it back in and is on his way off the mountain
  17. May 22, 2021 at 3:05 PM
    #37
    eon_blue
    Azusa, CA
    Sorry I can't head out that way, I'm on baby duty this afternoon. If you need help getting tools or doing a trail repair, post up on the SCOR FB page, they're very active and someone will certainly come out to help
    hoffengineering[OP] and tcjacado like this.
  18. May 22, 2021 at 3:05 PM
    #38
    eon_blue
    Azusa, CA
    Oh good to hear, didn't read the whole thread haha.
    whatstcp and tcjacado[QUOTED] like this.
  19. May 22, 2021 at 3:11 PM
    #39
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    :popcorn:
    :yes:
    tcjacado likes this.
  20. May 22, 2021 at 5:13 PM
    #40
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Back down at the highway, waiting on a tow. Thanks again for the input guys. Going to tear into it tomorrow to see if I can figure what exactly happened.
