Passenger Side Headlight Burning Out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by birry, Aug 13, 2019.
  1. Aug 13, 2019 at 5:20 AM
    birry
    birry [OP] Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    Ok, folks - help me out. I'm replacing the passenger side bulb about every 3 months. I have yet to burn out a driver's side (though I usually replace them in pairs). What's the deal???
    Completely stock 2008 DCSB V6 except for some suspension upgrades. Yes, I wear the gloves when I replace them, etc..... I've read other people having this problem, but haven't seen the solution.
    What's the go-to solution for this annoying problem?????? And I don't want to go HID or something illegal / annoying. I want something that works within the law and is safe for oncoming drivers.
  2. Aug 13, 2019 at 7:52 AM
    caribe makaira
    Caribbean, Puerto Rico
    Could be loose fitting terminal and/or bad wiring to specific lamp.
  3. Aug 13, 2019 at 8:10 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    High resistance in one or more of the circuits to that bulb is most likely causing the reduced bulb lifespan. Or it could just be 'bad' bulbs (even good brands have bad days on the assembly line).
    Voltage-drop test the circuits to the headlamps to determine where the fault is. Inspect the terminals in the related harness connectors for loose/bent pins, corrosion, and/or fretting. Use the wiring diagrams and connector location diagrams as your guide [factory service manual].
    Let us know what you find.
  4. Aug 13, 2019 at 10:48 AM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    You can pull the wires and connectors out of the plug with a small screwdriver and gently bend the connectors to clamp tighter to the bulb blades. This worked for me. Just remember which wire went where in the plug.
    birry[OP] likes this.
  5. Aug 13, 2019 at 11:17 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the connector "burned out" or the bulb filament?
    When bulb is working, is it the same brightness as the other side?
  6. Aug 13, 2019 at 11:21 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I'm assuming that you're you just replacing the passenger side. Bite the bullet and replace both driver and passenger. The difference in voltage/resistance although minimal can be the culprit. Make sure the connectors are clean, get some dielectric grease. Volvo's were notorious for having to replace both sides no matter which bulb it was. Good luck.
  7. Aug 13, 2019 at 11:23 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I haven't seen a connector burned out. Just the filament burned through..... And yes, it seems to be the same brightness on each side.
    b_r_o[QUOTED] likes this.
  8. Aug 13, 2019 at 11:24 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I've always replaced them in pairs. So that's not the issue.
    Drainbung[QUOTED] likes this.
  9. Aug 13, 2019 at 11:27 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You probably just got a run of poor quality bulbs all in a row. If you had a wiring problem that was causing extra resistance there would be less power making it to the bulb filament. If anything that would extend the life of the filament, not shorten it..
    I wouldn't worry about a wiring problem, get some good quality bulbs I like Osram or Sylvania ( they might even be from the same company LOL)
    There is some good info regarding headlight bulb quality in this thread
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    Drainbung likes this.
  10. Aug 14, 2019 at 4:58 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    Great thread, btw. I've read it before.
    I have been getting Sylvania Silverstar in various levels over the last two years. I seriously doubt that I got unlucky on 5 different bad runs.
