Passenger side keyed entry??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paraguay, Apr 17, 2012.
  1. Apr 17, 2012 at 9:58 AM
    paraguay
    paraguay [OP] Cheesehead
    Northern Wisconsin
    V6 Manual 6-speed
    Hey All,
    First post so bear with me...
    I just got my 2012 Tacoma V6 manual 6-speed last week to replace my 2005 4 cylinder 5-speed. I don't like the electronic key fob to open the doors, so I always use my key. it's very frustrating that the passenger side door can't be opened with a key.
    Can I have a key installed on the passenger side relatively easily and cheaply? at this point I don't even care if the key matches the driver's side.
    Thanks.
  2. Apr 17, 2012 at 10:20 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) You can unlock your passenger side door from your key. You just need to turn your key to right once to unlock the driver's door, and turn the key once again to the right you can unlock the passenger door.
    I know that doesn't help if you are on the passenger side, but that is the way that Toyota tries to save a dollar. I don't know if you can add a lock to the passenger side, maybe one from a earlier taco may work.
  3. Apr 17, 2012 at 10:28 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Wow, crazy. They can spend extra for the driver key to be able to unlock the passenger door but can't put a key hole on the passenger door so you can be all gentlemanly for your lady if not using the fob or if the battery happens to be kaput? FAIL!
    Even with the fob working it's nice to escort your lady to her door and even open/shut it for her before going to get in on driver side.
  4. Apr 18, 2012 at 4:54 AM
    paraguay
    Northern Wisconsin
    V6 Manual 6-speed
    Ya, I'm always approaching the truck from the passenger side (or so it seems) with stuff or the dog that go in that side but have to first walk around the truck to open the door from the driver's side since I don't like the fob - too bulky in my pocket...
  5. Apr 18, 2012 at 6:19 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I use to hate carrying cell phones around too....:rolleyes:
    EMS911 likes this.
  6. Apr 18, 2012 at 10:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Cell phone on belt clip.....key hole in each door.....no fob.
  7. Apr 18, 2012 at 10:20 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    They must have changed something...I can open up the passenger door on my 07 with the key. I just stick the key in the passenger door and turn once.
  8. Apr 18, 2012 at 10:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    There's no keyhole on passenger side on 2012 trucks it seems.........lame shit.
  9. Apr 18, 2012 at 10:23 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    i dont have the passenger side key hole on my 06
  10. Apr 18, 2012 at 10:23 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Ditto.
  11. Apr 18, 2012 at 10:27 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check the base model listing for the door handle. It should have a key for each side. Check to see if the door latch is the same part number. You might need operating rods as well.
  12. Apr 18, 2012 at 10:42 AM
    Toytruckmike
    Toytruckmike Well-Known Member
    Michael
    Texas
    07 TRD Sport AC 4x4 manual
    Eclipse nav unit, TRD Yeti decal, 18" 4Runner limited wheels finally installed! Look great
    My 98 Tacoma had a lock on the gas cap cover. Cutbacks. Toyotas standard practice anymore. I also had a vent window on my 98 access cab. Those are gone too. Miss both of those features.
  13. Apr 19, 2012 at 3:39 PM
    paraguay
    Northern Wisconsin
    V6 Manual 6-speed
    Thanks Skytower, I'll check on the base models.
  14. Apr 19, 2012 at 3:43 PM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    Odd never knew I didn't have a key hole over there. But sure enough...I don't.
  15. Sep 26, 2012 at 7:49 PM
    cheerios
    cheerios New Member
    '10 Tacoma Double
    So did you figure this out? I have the same problem. I wonder how a keyed entry would work with the security or noise-making system in the vehicle?
  16. Sep 26, 2012 at 9:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Life is sweet when all you can find to bitch about is carrying a key fob and no key hole in passenger door.
    :p
    Wow!
  17. Sep 27, 2012 at 6:34 AM
    cheerios
    cheerios New Member
    '10 Tacoma Double
    For sure it is...I guess you don't know the answer?
  18. Jun 26, 2013 at 12:22 AM
    McBean
    McBean New Member
    Los Angeles
    07 PreRunner Sport Shortbed
    Can you guys help a new member?
    I just bought an '07 Tacoma DoubleCab. I got it from the dealer and it only came with one standard key, no fob and no transmitter type key. The next day I realize the doors can't auto lock/unlock from the drivers side door and as this thread states, despite a key hole on the passenger door, I can't unlock only auto lock from that key hole. Inside the cab the power lock button only allows power lock but not power unlock.
    I tried doing that programming code that is like old school Nintendo cheats (open door close door key in key out, etc) that didn't work. So my question is, has anyone else had these problems and know of a solution? Is this because of the missing alarm fob, transmitter key? Or just bad wiring or actuator? I also just noticed my temp/compass doesn't work either. It sucks to be having problems on the second day already, but I'm happy they aren't engine or anything too technical. Any help/advice will be greatly appreciated. Thanks!
  19. Jun 26, 2013 at 2:36 AM
    MadMan
    MadMan Well-Known Member
    Indy
    13 TRD sport
    De-badged and blacked out
    There is a fix for your temp/compass thing, do a search.
    As far as key, go back to the dealer and tell them you want remote at no charge. It's not your fault they took a truck in trade without it...
  20. Jun 26, 2013 at 3:13 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Sounds like a lock issue to me, if nothing will lock them. Wonder if the person had an aftermarket alarm installed and did a crappy job uninstalling it??
