Passenger side power window stopped working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snappa, Sep 23, 2015.
  1. Sep 23, 2015 at 2:38 PM
    snappa
    snappa [OP] Snappa
    Rhode Island
    2011 PreRunner Access Cab
    Today the passenger side power window stopped working. Stopped in the closed (thankfully) position. Drivers side window OK. No other electrical issues found. Checked under dash fuses #'s 11 & 16--Both OK. Need suggestions to try before bringing to dealer. TIA
    Snappa
    2011 Pre-Runner, 2WD, auto, 6 cyl, 63,000 mi
  2. Sep 23, 2015 at 3:45 PM
    Mfreund1
    Mfreund1 Well-Known Member
    Eastern Ia
    2007 SR5 Sport
    Try it with passenger door switch and see if it works.
  3. Sep 23, 2015 at 5:08 PM
    snappa
    snappa [OP] Snappa
    Rhode Island
    The window will not work using neither the driver's door switch nor the passenger door switch.
    snappa
  4. Sep 23, 2015 at 9:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the Window Lock Button on the driver door control. If it is pressed you will get this issue.
    JDawg562 likes this.
  5. Sep 24, 2015 at 7:39 AM
    snappa
    snappa [OP] Snappa
    Rhode Island
    DUH!!!!!!!!!!!!! Thank you, thank you, thank you from one very foolish feeling old buzzard!!!!!!!!!!!
    Snappa :) :) :)
  6. Sep 24, 2015 at 3:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It is usually the simple things that get you. Glad you got it.
