Passenger side tail light assembly replacement
Discussion in 'Lighting' started by pantherius, May 7, 2010.
  1. May 7, 2010 at 10:33 AM
    pantherius
    pantherius [OP] LJAZ
    LJ
    Arizona
    2008 Pre-runner sr5 offroad
    So, I need to change my passenger side tail light assembly. I can either get it at Toyota at cost for 110 bucks, or go on Amazon.com and get it for like 70. Either way, install myself. Looks relatively simple, but if someone has some suggestions I will gladly take them on either a) I better place to get the part, or b) the best way to change it all out.
    Thanks!!!
  2. May 7, 2010 at 10:50 AM
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    They're really easy to get out. 2 10mm bolts and they (literally) POP out in 2 places. Quarter turn on the bulbs and they're out.
    OEM is always better than aftermarket. You're best bet would be to try to find someone selling the one light you need either on here or on craigslist.
    When I smashed one of my tail lights, I got a pair of OEM's that looked brand new for $50 + shipping. I just turned around and sold the one good light that I had for almost the same price.
  3. May 7, 2010 at 10:54 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Super easy to install. If your going to mod up your truck, they have a bunch of different ones on ebay for pretty cheap to so you might want to check them out.:rolleyes:
  4. May 7, 2010 at 11:01 AM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    If you go the egay way, keep in mind that those lights will not last as long as OEM. The sealant on those aftermarket lights is cheap and tends to let moisture into the light much sooner than an OEM light would.
    The aftermarket headlights are more of a problem because the lenses fog up and oxidize within just a few years + the sealant problem.
  5. May 7, 2010 at 12:09 PM
    pantherius
    LJ
    Arizona
    I just need to replace the factory one. Not making modifications yet :) Soon I hope! Just tagged something backing up (first mishapp in 10 years. sweeet), small nick in the tail gate, and the tail light cover popped right off. Should be easy, but 100 bucks? :eek:
  6. May 7, 2010 at 12:13 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Like I said, you best bet would be to buy a pair for around $100 from somebody on this site and sell the one you didn't use for 50-60ish.
  7. May 7, 2010 at 12:14 PM
    pantherius
    LJ
    Arizona
    Thanks!!! :)
  8. May 7, 2010 at 12:16 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Not a problem. Good luck backing up from now on.
  9. May 7, 2010 at 3:04 PM
    pantherius
    LJ
    Arizona
    HAHA scars my perfect record! Battle wound...
